Not starting
Old Mar 17, 2024 | 09:39 AM
Dysfunctional's Avatar
Dysfunctional is on a distinguished road
Not starting
Hi All,
new here so this may have been answered before. If it has I'm sorry.
My ccts failed at 18000 miles and I fitted new manual ones. The cams timings went very squiffy and I had to reset them.
I put everything back together, the bike turns over but will not start. I have correct voltage, sparks on the plugs.
Does anyone have any idea of what could be wrong?
The bike was sitting for 2 months before I changed the ccts.
Does anyone have an image of where the fuel pipes go onto on the manual shut-off valve?
Many thanks everyone
Old Mar 17, 2024 | 10:00 AM
If you had a CCT failure and your timing went squiffy, have you checked compression? This is a zero clearance motor.
Old Mar 17, 2024 | 11:40 AM
Seems fine
Old Mar 17, 2024 | 11:49 AM
Bad news is the valves are most likely bent. As thread killer suggested, check the compression.
There is a better photo and explanation somewhere, but I can't find it. The 90° nipple on the back of the fuel valve is where the vacuum line goes.
https://www.superhawkforum.com/forum...ix-pics-19843/
Old Mar 20, 2024 | 08:40 AM
Compression is great. No spark at plugs . Didn't have any issues like this before fitting the new CCT's
Old Mar 20, 2024 | 06:33 PM
Check if there is voltage to the coils. Maybe you pulled a wire loose.
Old Mar 21, 2024 | 08:20 AM
Thank you. Next jobbie to do 👍
Old Mar 21, 2024 | 04:47 PM
After trying to start, have you pulled a plug and checked to see if it's getting gas?
Old Mar 22, 2024 | 07:49 AM
Yes,bit getting petrol alright. Ordered new iridium spark plugs, old ones were rusty and corroded.
Old Mar 22, 2024 | 07:52 AM
Where at coils do I check? Big lead going off as spark plug lead or the ones going in to the connector?
Any help appreciated
Old Mar 23, 2024 | 06:45 AM
Not sure how to get a reading without the special tool. Maybe back probe the connector.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 24, 2024 | 02:53 PM
Thanks a million. Better get a decent multimeter so
Old Mar 26, 2024 | 04:26 PM
Squid's Avatar
From a different way of thinking but, make sure the ignition pulse generator connector is connected since you were doing maintenance in that area. It comes thru the clutch case towards the front of the engine and is yellow and yellow / white 2 wire connector.
luis saleiro
Apr 25, 2010 04:25 PM
super duper hawk
Oct 15, 2009 06:26 AM
super duper hawk
Oct 10, 2009 06:40 PM
finepooch
Apr 20, 2009 05:26 PM
roadrun_fr
Sep 21, 2005 07:00 PM
