stuttering, bucking, misfiring at steady 2-4k rpm
Old Jan 10, 2007 | 09:54 AM
zimm's Avatar
zimm is on a distinguished road
The superhawk is acting up. At steady speed between 2000-4000rpm, like going 30mph, the engine "hiccups" quite a bit. It sounds like a misfire, engine bucks and then smooths out. I think it's running lean, but I'm not sure. I have devil pipes and a K&N jet kit. The jet kit has been in place for 22,000 miles with no problems before.
I'm thinking about re-syncing the carbs and checking for vacuum leaks. Maybe I should also change the plugs. Any other suggestions? Anyone have this problem?
It runs great while accelerating or running on the highway.
Old Jan 10, 2007 | 01:05 PM
superbling's Avatar
Mine was behaving identically and in roughly the same condition (jet kit, pipes, mileage) as yours. Going up a notch on the needles did the trick.
Old Jan 10, 2007 | 01:13 PM
zimm's Avatar
Raise the needles a notch, or raise the clip a notch on the needles?
Old Jan 10, 2007 | 11:50 PM
+1
Then sync the carbs. Clean your air filter too.
I think he meant go richer, which would be lowering the clip, thus raising the needle.
Old Jan 12, 2007 | 02:20 PM
Mick-e's Avatar
Mick-e is on a distinguished road
Are the needles titanium?
Old Jan 12, 2007 | 03:01 PM
zimm's Avatar
No, stainless steel. I just raised them a notch this afternoon and re-sync'd the carbs too. I'll do a test ride tomorrow and report back.
dm440c
Feb 29, 2012 05:29 PM
CentralCoaster
Sep 13, 2008 12:51 AM
kenhawk
Aug 24, 2008 08:10 PM
ghopki1
Jul 28, 2008 06:20 AM
iamanonymous
Mar 7, 2007 03:13 PM
