a strange knock
Old May 5, 2009 | 01:43 PM
merlyn's Avatar
merlyn is on a distinguished road
a strange knock
Hello!After I ve changed the stock air filter with an BMC race I started to hear a noise in the engine!The noise is not from the cluth lever in neutral as usual! It looks like a tac tac but insignifiant!would I syncronise the carbs_?I dont think that CCT comes out at 19k miles? WTF ...the oil I put in my engine is fully syntetic MOTUL 300 V racing line double ester 10w 40! all other times I run castrol 10 w 40 with no problems, no strange sounds, rarely slide the 2nd gear!Thank s
Old May 5, 2009 | 01:56 PM
Probably the slides clacking.. perfectly normal. Did you rejet for the filter? (won't affect noise, but will help performance - smooth running)
Old May 5, 2009 | 02:04 PM
merlyn's Avatar
nop!but I feel the acceleration 10 procent more and no missfire
Old May 5, 2009 | 02:16 PM
merlyn's Avatar
and the noise from engine at idle_?it s something like a knock but almost unsignifiant???
Old May 5, 2009 | 02:20 PM
merlyn's Avatar
I heard in a forum about TPS!I dont know what it means ?? it could be the problem?
Old May 5, 2009 | 02:45 PM
TPS is the Throttle Position Sensor, and properly adjusting this will help how your engine runs at lower RPMs. However it probably won't affect the sound. If you search for Slides you will find quite a few threads where this comes up. It could be CCTs but I think that is unlikely, noisy slides is more likely. The slides make a slight tapping noise, and that is totally normal, nothing wrong.
I recommend everyone get their CCT's swapped out to manual ones just for peace of mind, but they have to be installed correctly. (you can't just pull the old CCTs off, that will mess up your engine)
Old May 6, 2009 | 01:57 AM
shayne's Avatar
Can you hear the noise at idle?
Old May 6, 2009 | 02:19 AM
merlyn's Avatar
yeap only at idle!when the engine is warm enough the knock goes away
CruxGNZ
Apr 25, 2015 07:53 PM
follmer_af
Aug 5, 2008 11:21 PM
CentralCoaster
Jul 5, 2008 04:54 PM
Lilbitz909
Jun 29, 2006 12:23 PM
reelectreagan
May 25, 2005 01:51 PM
