starting engine after prolong storage
Old Apr 22, 2019 | 08:01 AM
wheels's Avatar
wheels is on a distinguished road
I have bought a bike sitting since 2013 any thoughts on turning it over was. had no oil in it when stored? Was worried about cam chain tensioners
Old Apr 22, 2019 | 11:52 AM
Id squirt a bit of oil on the cylinders before turning over...
I would change oil and coolant before first start.
I would crank it over no spark plugs for 20-30 sec, then put plugs in, then start so it can build oil pressure with no compression before first start.
Were it me, id pull And replace the ACCTS with manual CCTs before first start, if your not going to do that Id suggest at least removing and inspecting the front ACCT for corrosion on the spring....then toss it in the bin and install a MCCT...LOL
Old Apr 22, 2019 | 01:04 PM
wheels's Avatar
lol I was kinda thinking the same thing ,don't want to destroy the motor right off thanks
Old Apr 22, 2019 | 01:20 PM
I’d pretty much do the exact same thing as Erik suggests. Good luck.
whatthefnck
Mar 30, 2013 07:18 PM
Byrdman
Sep 28, 2009 07:39 PM
F1 Fan in Nascar Land
Jul 12, 2007 12:10 PM
ali_squidz
Apr 7, 2007 05:57 PM
StoneJrW
Feb 20, 2007 07:21 AM
