Speedo acting strange
Old Sep 9, 2011 | 08:28 PM
20_rc51_00's Avatar
So today after 3 wks of the bike sitting I take it for a spin and notice that the speedo goes nuts up and down randomly while at a stand still. The bike has a speedo healer but was working normally before.
I'm thinking that I will try and charge the battery and then disconnect the healer and see if it resolves it. the bike is a 98 with analog gauges.
anyone ever have this happen?
Old Sep 9, 2011 | 08:38 PM
superhawk22's Avatar
Had it happen once with my '98 when the regulator/rectifier went bad. check the connector for burnt wires and or a burnt spot on the R/R, very common problem, I ended up using an R1 R/R after the 2nd one went bad.
Old Sep 9, 2011 | 08:43 PM
20_rc51_00's Avatar
haha lol if that's the case then it will be about time I put the new one in. I also have a R1 type r/r ready to go. If this is the case i'm lucky the bike didn't crap out while I was far from home...
Old Sep 9, 2011 | 08:52 PM
Yep damn lucky I had to jump start mine 4 or 5 times to get home, about a 12 mile trip!
Old Sep 11, 2011 | 07:33 PM
20_rc51_00's Avatar
go the rr replaced and mounted some new tires aswell. No more funny speedo action. Thanks. (but I think it really was the tires )
Old Sep 13, 2011 | 09:02 PM
No problem, glad the tires worked out for ya!
Old Sep 17, 2011 | 06:31 PM
20_rc51_00's Avatar
well the speedometer is acting weird again. it bounces all around when the bike is not moving and when it is in motion the speedo is a bit jittery. I replaced the RR last week and the voltages etc are all in spec. any ideas what else could be the matter? THanks.
Old Sep 17, 2011 | 06:50 PM
thetophatflash's Avatar
load test the battery?
Old Sep 18, 2011 | 01:35 AM
Wicky's Avatar
The Speedo Sensor can start acting weirdly when it fails. Check connections from where it goes in rear pot next to CCT, and to where it plugs into loom.
Little_Horse
May 17, 2008 01:46 AM
loserbaby
Sep 21, 2007 10:36 PM
hazzy
Aug 26, 2007 07:50 PM
nova_scotian_996
Apr 25, 2007 02:58 AM
call me phil
May 17, 2005 05:49 AM
