Speedo acting strange
So today after 3 wks of the bike sitting I take it for a spin and notice that the speedo goes nuts up and down randomly while at a stand still. The bike has a speedo healer but was working normally before.
I'm thinking that I will try and charge the battery and then disconnect the healer and see if it resolves it. the bike is a 98 with analog gauges.
anyone ever have this happen?
Had it happen once with my '98 when the regulator/rectifier went bad. check the connector for burnt wires and or a burnt spot on the R/R, very common problem, I ended up using an R1 R/R after the 2nd one went bad.
haha lol if that's the case then it will be about time I put the new one in. I also have a R1 type r/r ready to go. If this is the case i'm lucky the bike didn't crap out while I was far from home...
well the speedometer is acting weird again. it bounces all around when the bike is not moving and when it is in motion the speedo is a bit jittery. I replaced the RR last week and the voltages etc are all in spec. any ideas what else could be the matter? THanks.
hazzy
Aug 26, 2007 07:50 PM
