Small hole in Crankcase cover!!
Old 06-09-2005, 06:15 AM
jschmidt's Avatar
jschmidt
Coolant leak. There is a service bulletin about it.
jschmidt is offline
Old 06-09-2005, 09:48 AM
L8RGYZ's Avatar
Re: Small hole in Crankcase cover!!
I bought a '98 myself last October. Right after I bought it, I noticed the hole you're speaking of and a drop or two of coolant (at first I thought it was oil, but that was from dirt/coolant mixture...a closer look revealed the green tinged stuff). I was pretty concerned at the time. Several knowledgeable Super Hawk owners told me what it was.
It's a "weep hole" for the water pump. On later models Honda added a fitting and a drain hose to it.
Some people advised me that most VTRs will pass a small amount of coolant past the seals & not to worry as long as it's not excessive. They also said that often the weeping will stop on its own. This was the case for me. I'm guessing that mine sat idle for quite a bit & that the almost daily thrashing I give it now has "re-hydrated" the seals & stopped the leak. (This is just my uneducated reasoning, however.)
Don't worry about it unless you're getting a lot of coolant leakage, then you'd need water pump seals.
No worries mate...you should be fine.
L8RGYZ is offline
dr_gonzo
06-11-2012 04:28 PM
StuDaddy
08-15-2010 09:26 AM
fundgh
06-08-2007 02:22 PM
quakefiend420
05-19-2007 12:44 AM
ClevelandSuperhawkRumble
03-15-2005 08:06 PM
Quick Reply: Small hole in Crankcase cover!!
