Small hole in Crankcase cover!!
Guest
Posts: n/a
While changing the oil in my recent purchase of a 98 Superhawk I discovered oil residue. I am wondering if anyone else has this very small hole in theirs to. It looks like its suppose to be there but not sure. If looking on the right side of bike front of the engine, look right around where the water pump is located and the coolant hoses run out. I thought it might be a crankcase breather so the bike doesnt get a build up of pressure in the crankcase. Please can someone verify what I am seeing.
Re: Small hole in Crankcase cover!!
I bought a '98 myself last October. Right after I bought it, I noticed the hole you're speaking of and a drop or two of coolant (at first I thought it was oil, but that was from dirt/coolant mixture...a closer look revealed the green tinged stuff). I was pretty concerned at the time. Several knowledgeable Super Hawk owners told me what it was.
It's a "weep hole" for the water pump. On later models Honda added a fitting and a drain hose to it.
Some people advised me that most VTRs will pass a small amount of coolant past the seals & not to worry as long as it's not excessive. They also said that often the weeping will stop on its own. This was the case for me. I'm guessing that mine sat idle for quite a bit & that the almost daily thrashing I give it now has "re-hydrated" the seals & stopped the leak. (This is just my uneducated reasoning, however.)
Don't worry about it unless you're getting a lot of coolant leakage, then you'd need water pump seals.
No worries mate...you should be fine.
StuDaddy
Aug 15, 2010 09:26 AM
quakefiend420
May 19, 2007 12:44 AM
ClevelandSuperhawkRumble
Mar 15, 2005 08:06 PM
