Slurp, Pop, lots of smoke?
Old Nov 22, 2009 | 03:25 PM
zmaniv's Avatar
What the hell is that. I took the bike out for a spin today, had a couple of carb farts then after 45 minutes of riding I'm sitting at a red light then the bike makes a slurp sound, then its like a really large carb fart followed by lots of smoke mostly fuel smoke. When I got home I smelled like someone poured gasoline on me.
Anyone have any ideas?
Old Nov 22, 2009 | 04:04 PM
Sounds like the float/s might be stuck dumping fuel en masse into the engine... Check before you vapour lock it...
Old Nov 22, 2009 | 04:54 PM
dshakes's Avatar
dshakes is on a distinguished road
Slurp,pop,lots of smoke? ummmm....
Old Nov 23, 2009 | 03:05 AM
cnw126's Avatar
cnw126 is on a distinguished road
Yea, sounds like my youth!
Seriously, check the floats, make sure all vacuum lines are connected ect...
Old Nov 26, 2009 | 08:39 AM
c-dub's Avatar
c-dub is on a distinguished road
+1
Old Nov 28, 2009 | 09:43 AM
superchickencornermonster's Avatar
Brooks' Cycle Centre'
superchickencornermonster is on a distinguished road
Sticky floats... more than likely. If that does not work, while you are in there make sure that the main jet is all the way tightened. I've seen that give similar symptoms. Also, check your oil. If you have too much oil, the excessive pressure causes weird things to happen like running very rich, what not. Of course, if you have too much oil, it may be due to a sticky float bowl letting gas get into the crank via cylinders and/or breathers from the air box.
Letsrideinsc
Sep 3, 2009 03:16 PM
finepooch
Aug 22, 2008 05:30 AM
tommygdbr
May 18, 2007 03:03 PM
roadrun_fr
Aug 6, 2005 05:47 AM
ClevelandSuperhawkRumble
Mar 13, 2005 03:09 PM
