Simple Front Sprocket Removal Question...
OK Boys.... simple one...
To REMOVE to front sprocket bolt... Counter clockwise or Clockwise? Just wanna be sure I'm going the right way before I do something stupid and break it or strip it by going the wrong way... as I know sometimes items like these can be threaded "backwards" to insure they won't back out.
Thanks...
J.
Thanks...
J.
We gotta quit meeting like this. I read all the posts down the page thinking to myself, "no, I don't think so." "no, that is incorrect or not my experience" then I get to your post. This I trust because I know you've done it more than once.
Lefty loosey, righty tighty! Thanks for your help.
Bolt comes out counter clockwise.Put a piece of 2x1 wood through the wheel,resting on top of the swingarm.This will stop movement of the sprockets,chain,wheel. Remove bolt and if necessary tap the sprocket with a small hammer towards the motor to loosen.Note the profile of the sprocket,thick side goes inwards.... Good luck.
Thanks all...... I know the procedure well, but just wanted to make sure I didn't force the bolt in the wrong direction by accident!!! Counter Clockwise - Lefty Loosey it is!!!
J.
J.
Haven't found a left-handed thread on the Superhawk yet. Am sure that bolt is lefty-loosey... I have a grade-8 replacement bolt in place now after I used a 3-foot breaker bar and sheared the old one off. Thought the same thing you did, "But it spins that way. Why wouldn't you put a left-hand bolt on there?" D'oh!
UPDATE!!!!
Yes, it's lefty loosey (Counter clockwise) to remove.
And... if you have an impact gun... put the bike in first gear and hit it... 2 seconds and it's off... and I didn't even have a chain on it!!!! I love air tools!!!.
J.
J.
