Replacing Clutch Lever
Old Dec 7, 2012 | 04:32 PM
memmakersorg's Avatar
memmakersorg is on a distinguished road
Hi,
I need to replace the clutch lever on my SH.
Does someone have a link to a good video or article that explains how to change it.
Thanks.
Old Dec 7, 2012 | 06:31 PM
Search this forum (maybe knowledge base) for the repair manual. I believe everything on the bike is covered there. Its a pdf you can download then print the page you need.
Old Dec 7, 2012 | 08:33 PM
Just remove the nut and bolt securing the lever to its mount, then install the new lever. There are no surprises. Use moly lube, or some type of semi-heavy grease, to lube all friction points. And don't tighten the bolt too tight. It needs to operate freely.
Old Dec 8, 2012 | 06:20 AM
comedo's Avatar
The clutch lever has a cylindrical brass insert in it with an indentation. There's a small post in the plunger the lever pushes against that has to fit into the indentation. Other than that, it's pretty much the same as changing the brake lever. It'll probably take more time to find a flat screwdriver, grease and a 10 mm. wrench than it will take to change the lever.
Old Dec 10, 2012 | 12:43 AM
Thanks guys,
I found me this one on ebay
Honda VTR1000 F Super Hawk Clutch Lever 98 05 | eBay
Look good to you guys?
Thanks.
Old Dec 10, 2012 | 07:23 AM
My 2 cents is to look for brake and clutch together. You'll save on shipping and bikes inherently/inevidably tip, breaking levers. This leaves you stranded til a new one comes so always keep spares.
Something like this Honda VFR 800 VFR800A Inteceptor VTR 1000 Black Brake Clutch Hand Lever Set | eBay
Surfer, I mention the manual because it seems if someone is even asking the question about the lever, then yeah, there will be surprises.
Mem, take pics and ask questions. Knowledge abounds on here and you have to start learning somewhere.
Old Dec 10, 2012 | 07:47 AM
killer5280's Avatar
My advice exactly. In fact, I just did this last week and the psychomotogear levers work just fine. If you don't like black they have them in plain old polished aluminum, which is what I bought.
Honda VFR 800 VFR800A Inteceptor VTR 1000 Polish Brake Clutch Hand Lever Set | eBay
For about 10 bucks more you can get the cheap Chi-nee Pazzo knockoffs, but there is nothing wrong with the stock style levers.
memmakersorg
Nov 12, 2012 08:31 PM
acarp
Sep 20, 2009 11:14 PM
AJK
Sep 11, 2008 06:17 PM
Randman
Oct 16, 2007 02:04 PM
Otto Man
Jan 6, 2007 01:36 PM
