Rejet and air filter.
Old May 2, 2007 | 09:28 PM
trinity012's Avatar
Hi I work on my vtr's carb jetting right now (factory jet stage 1) and might as well i also want to replace oem air filter, but searching about K N air filter seems like that are alot of isues w/it. So what you recommend? Stick w/oem install new jet kit or should i go w/K N a/f? And what is base line? I believe someone member of this forum talk to VTR guru and not recommend to replace it w/aftermarket air filter Thanks Gents for helps and advices.
Old May 2, 2007 | 09:48 PM
What exhaust and elevation?
Old May 3, 2007 | 10:15 AM
trinity012's Avatar
Hi Greg, I have leo vince slip on and i dont know what is the elevation at where i m at (bloomington ,IL). Thanks for your respond.
Old May 3, 2007 | 11:24 PM
I think you could go for the K&N and be successful.
Go for 2.25 turns on the mixture screws
needles with the clip in the middle (3rd) notch
182r/180f mains (185r/182f if you're feeling frisky )
Old May 4, 2007 | 06:56 AM
trinity012's Avatar
Hi Greg.
Should I do a carb sync after jetting? Thanks.
Old May 4, 2007 | 07:42 AM
Zedicus's Avatar
Zedicus is on a distinguished road
im running K&N with D&D slipons at about 3000ft elevation
jetting is 48 pilots 3 turns out (2.75 woulda been perfect but im to lazy to pull the carbs again for that.) with 190r/185f (i only had steps in 5) also if u r going to stay with the stock size 45 pilots you should get some non 'S" varients. they hav larger air holes and make the air and fuel mix better.
Old May 4, 2007 | 08:41 AM
Yes on the carb sync, if for no other reason just to make sure it's still adjusted correctly.
Old May 4, 2007 | 08:45 AM
swordfish's Avatar
I don't have jetting advise other than saying it's advantages might not be worth the trouble. have you researched what the hp gain would be? anyway I am curious about your location. I'm in Aurora. how far from bloomington is that? I don't see many other superhawks out this way.
Old May 4, 2007 | 10:41 PM
trinity012's Avatar
Hi Swordfish, you re 1h30' distance from me, I think there someone member here live in peoria. If there is chance we should get together. The advantages of jetting quite noticeable i done it with all my others bikes except SHawk, CBR954rr.
Old May 4, 2007 | 10:49 PM
trinity012's Avatar
Hi Zed, do you have DJ or Fac Pro? My choke plunger plastic crew in the rear
broke on me when i try to disassembly, i took the piece of and super glue back together. So dont know i should order the whole new choke plunger's cable or what? thanks Zed
Old May 4, 2007 | 10:52 PM
trinity012's Avatar
Hi Greg, how do I find a kits like the one you have on your site? or do you got extra one for sell? thanks
Old May 5, 2007 | 04:03 PM
I don't think they sell them anymore, mainly due to the hazardous material concerns of mercury. You can try Googling Twinmax. That's a very good unit I've used in the past, though I do not own one. Only works for twins though. They may have another one for IL4s, or you could just switch out tubes.
Old May 5, 2007 | 04:52 PM
Zedicus's Avatar
i am running a DJ kit with 48 slow jets. had to order them seperate.
for the choke piecies i aquired some brass ones out some mikuni carbs that fit in place of the plastic one. polaris uses them on the 400 scrambler cars. posibly others but no garuntees. if u hav a polaris dealer getting them should be easy. you will hav to drill a small part of the brass out.. very easy mod to get choke inserts that dont break anymore.
Old May 10, 2007 | 09:09 AM
trinity012's Avatar
Hi, Jetting done now i m waiting for K N $72 fil come in and also got hi flo filtro
(replace OEM $30) a/f will put on test to see which one run better. My main jet 50 pilot 180f/182r 2.25 turn. Carb sync will be last to finish and waiting for
my twinmax sync balancer and i post to let you know how it work. Thanks Sirs
Old May 10, 2007 | 12:39 PM
If your idle is not steady and/or your plugs get fouled at idle speeds then I recommend you go back to stock #45 pilots or get some #48s to try.
Old May 10, 2007 | 12:54 PM
viperkillertt's Avatar
Josh
viperkillertt
that nearly happened to me last time i put my carbs back together, damn plastic crap!
Old May 21, 2007 | 07:20 PM
trinity012's Avatar
Hi, pilot jet 50 run just fine like your recommendation, plugs burn clean (i clean and check them befo install Fact Pro jet).
Old Jun 7, 2007 | 09:04 PM
GP996's Avatar
GP996 is on a distinguished road
Guys...good evening,
I just purchased a set of Akrapovics.....full system, racing line. Would anyone happen to know what jets I need to purchase for this setup? I plan on purchasing a K&N air filter, unless I'm told I should go another route. Any ideas? Thanks.
Old Jun 8, 2007 | 02:43 AM
gboezio's Avatar
I would try the carbs basic settings and start from there, then if any dead spots black smoke, carbon build up on plugs make the adjustments.
Old Jun 9, 2007 | 08:46 PM
Hammer7205's Avatar
Hammer7205 is on a distinguished road
A few weeks ago I dropped in Two Bros. Slip On's and a stage one jet kit. I justed dumped a K & N in her this week, and it did wake her up a little more. Just put a few hundred miles on her tonight going to the Americade, and there was a little more there after the K&N. I'd recommend it....
uchi
Apr 12, 2011 08:14 PM
Blueracer
Jun 4, 2010 07:36 PM
Sherm831
May 18, 2010 07:07 PM
j shizzy wizzy
Apr 18, 2010 02:26 PM
MLB
May 8, 2009 06:19 PM
