replacement cush drive rubbers
Old Feb 25, 2008 | 06:55 PM
bristunt's Avatar
bristunt is on a distinguished road
Question replacement cush drive rubbers
What do you guys in the USA pay for cush drive rubbers?
Is there an aftermarket supplier?
Brian
Australia
Old Feb 25, 2008 | 07:01 PM
Thumper's Avatar
Pretty cheap $25.00 US Dollars plus shipping for the entire set
http://www.ronayers.com/browseparts....e.ronayers.com
Old Feb 25, 2008 | 08:09 PM
Without being explicit, if your rubber are worn or loose in the slot, cut up an old inner tube into matching stripsand use them a shims to tighten things up.
And you thought I was going elsewhere. For shame.
Old Feb 25, 2008 | 09:48 PM
If you go with new, pick up a can of spray silicone. Give those guys a nice spray down before install and be sure to clean out all the gunk in the wheel.
Old Feb 25, 2008 | 10:38 PM
Spaz''s Avatar
Spaz' is on a distinguished road
+1 on the rubber shim
Yea, I think I used 1/16th" rubber shim. One layer on the inside of each cush' piece.
Rollin20z
Mar 15, 2013 12:08 PM
RPV-Hawk
Jun 30, 2011 09:54 AM
NovaWildcat08
Jun 21, 2007 07:16 PM
trinc
Mar 4, 2007 02:48 PM
FordsnRebels
Aug 22, 2006 06:33 PM
