replacement cush drive rubbers
What do you guys in the USA pay for cush drive rubbers?
Is there an aftermarket supplier? Brian Australia |
Pretty cheap $25.00 US Dollars plus shipping for the entire set
http://www.ronayers.com/browseparts....e.ronayers.com |
Without being explicit, if your rubber are worn or loose in the slot, cut up an old inner tube into matching stripsand use them a shims to tighten things up.
And you thought I was going elsewhere. For shame. |
If you go with new, pick up a can of spray silicone. Give those guys a nice spray down before install and be sure to clean out all the gunk in the wheel.
+1 on the rubber shim
Yea, I think I used 1/16th" rubber shim. One layer on the inside of each cush' piece.
