Replace with Stock R/R?
Old Apr 7, 2010 | 09:53 AM
99Hawkboy's Avatar
99Hawkboy
Ok so I see a lot of posts about replacing with an upgrade R1 regulator or R6 regulator but what about just replacing the regulator with a factory unit? Wouldnt this sound like a better option rather than having to rewire for quite possibly a junk pos used one?
What about these?
http://www.regulatorrectifier.com/ca...ator-Rectifier
I have a '99 and yes it still has the factory unit which just took a dump.
Thanks for the input guys!
Old Apr 7, 2010 | 10:03 AM
Wicky's Avatar
Presumably the R/R you had was OEM and unfinned - post 2000 the part was replaced by an upgraded finned one as you've linked to.
Yamaha ones are a cheaper if fiddlier option.
My 97 storm had its R/R replaced in 2002 with the later R/R and has been fine since.
Old Apr 7, 2010 | 11:10 AM
99Hawkboy's Avatar
99Hawkboy
Well looking at the website what is the difference in this one:
And This one:
Other than price...?
Old Apr 7, 2010 | 11:49 AM
Wicky's Avatar
Probably pattern parts to a better spec than the original 98-00 version, and on a par with 00-05 version
new Honda replacement part should cost ya $129
http://www.davidsilverspares.co.uk/g...4010_large.jpg
http://www.davidsilverspares.co.uk/p...tnumber_14930/
Pays ya money take your choice
Old Apr 8, 2010 | 01:20 AM
saige's Avatar
the boss
mine took a dump about 6 days ago,i found a 2000 yamaha yzf recetifier,the only 2 pins i had to change was positive and negitive,the 3 yellow i left alone and pushed onto connectors,bought a plug in to fit the recetifier,slid wires thru and done,took 20 mins,i got mine for 50 from a used motorcycle shop,the differnce in the new stock and yamaha recetifier is that the yamaha is bigger and has more fins to desipate heat,the new stock from honda is smaller still but does have fins,my opinion is bigger with more fins equals little more cooling.another solution is to go with after market recetifier,they go for about 100,give or take some dollars depending on site.
Old Apr 8, 2010 | 03:26 AM
residentg's Avatar
List of all Hondas that use that RR:
https://www.superhawkforum.com/forum...022#post261022
Old Apr 8, 2010 | 08:13 PM
Karbon's Avatar
Karbon is on a distinguished road
What about these?
Bought a Rick's from bikebandit.com. Which looks exactly like the one in the link you posted. No complaints so far. bout $95 shipped.
R/R Voltage output is a very steady 14.1-14.2 through the rev. range.
Much better than the OEM unit when it was working, which would fluctuate from 14.xx and spike to 15 on hard and abrupt revs.
Old Apr 9, 2010 | 05:01 AM
uchi's Avatar
i got this one right here
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
its twice as thick as the oem unit, and the guy gives a 1 year warranty too. complete plug and play
Old Apr 10, 2010 | 06:35 AM
nnjhawk02's Avatar
What about these?
I went here - no problem
http://www.ricksmotorsportelectrics.com/partsearch.php
Old Apr 11, 2010 | 08:20 AM
99Hawkboy's Avatar
99Hawkboy
Decided to go with a 06-07 R6 Regulator. Found one new on ebay for $32.76. Hell of a deal if I say so myself. Letcha guys know if it works.
Old Apr 12, 2010 | 07:31 PM
99Hawkboy's Avatar
99Hawkboy
Ok so i got the regulator. Problem is this baby has 6 plugs and mine only has 5.. So what about the sixth plug? I purchased one that looks exactly like this guys: http://vtr1000f.wickidnet.com/ and he said it doesnt matter what year... so.. Should i be good with wiring this guy up without using the sixth plug?
Old Apr 17, 2010 | 12:20 AM
mattijw's Avatar
mattijw is on a distinguished road
For what it's worth i just had mine replaced at a honda dealership under warranty and they fitted a third party copy one, not only that but it is apparently off a cbr1100xx blackbird they "modified" to fit .
Still lt's a nice big finned thing and the bike shouldn't be charging at 18v anymore! If it pops again (and i had to pay!) I'd go r6/r1 for definite.
Vincent
Jun 30, 2011 12:58 PM
Generation450X
May 25, 2009 07:14 AM
Randman
May 2, 2006 04:25 PM
ta2av
Dec 3, 2005 12:45 PM
CNI Dawg
Nov 11, 2005 03:44 PM
