Red Dot on Pirelli Tires - light or heavy?
Old Feb 19, 2012 | 11:46 AM
cliby's Avatar
Simple question. My first time with Pirellis (rosso corsas). They have 2 small red dots.
I'm used to one yellow dot on dunlops. I searched and have read conflicting things: is this the light or heavy spot of the rim. Dunlop puts in on their website. I can't find on the pirelli site. So does anyone know for sure which the red dots on pirellis are marking? Light , heavy or high spot on the tire.
thanks
Old Feb 19, 2012 | 01:12 PM
aja's Avatar
aja
Usually its heavy and opposites the valve stem, could be wrong though.
Old Feb 19, 2012 | 03:29 PM
Tormoz's Avatar
Tormoz is on a distinguished road
This from Motorcycle Tire/Tyre Tech 101 :
"Some PIRELLI tyres have a red dot on the sidewall. This indicates the lightest point, and should be positioned next to the valve."
Old Feb 19, 2012 | 05:42 PM
cliby's Avatar
that is the only reference I could find also. thanks guys
Old Feb 19, 2012 | 09:46 PM
...unless you have a static balancer, in which case I recommend balancing the wheel without the tire and then marking the heavy spot. Mark the inside of the rim with a sharpie and align the dot to that instead of the valve stem. 90% of the time the heaviest part is not at the valve stem.
Old Feb 20, 2012 | 06:44 AM
cliby's Avatar
thanks again. yes I use a balancer and do just as you suggest. and the heavy spot was about 70 degrees away from the valve stem.
Northman69
Mar 17, 2013 06:27 AM
wormeater
Nov 11, 2006 02:07 PM
Tempest
Sep 13, 2006 12:01 AM
mikecronis
Jul 16, 2006 07:44 PM
EngineNoO9
Jun 19, 2006 09:55 AM
