Head Gasket
Old Feb 14, 2012 | 12:18 PM
jay956's Avatar
Head Gasket
Haven't really looked closely at it yet as my bike is at a friends house. But at the end of my weekend at the track I saw a little oil leaking down from what looked like the rear cylinder. How likely is it that the head gasket would go out on the Superhawk? It has almost 53k and hasn't had an easy life so it wouldn't surprise me. And if I do replace the gaskets is there anything else I should do while I'm in there? I would go ahead and check the compression first to see about rings, and measure everything while its apart.
Old Feb 14, 2012 | 01:12 PM
Not likely. It's probably the oil pressure sensor or the cam chain tensioner. On the right side, correct?
Old Feb 14, 2012 | 01:51 PM
jay956's Avatar
Left side, cct was my first thought too but was too far back I think. Ill just have to start tearing it down when I get some time.
Old Feb 21, 2012 | 12:17 PM
jay956's Avatar
Got a close look today. The left side of the rear head gasket is quite wet, as well as the left side of the front. Stator cover has a nice coating of oil on it from somewhere above and I'm guessing it's the heads.
Old Feb 21, 2012 | 12:46 PM
VTaRse's Avatar
aka tony.mon, vtr1000.org
VTaRse is on a distinguished road
The draft as you're riding blows any oils all over the place, so I'd suggest you clean it all off thoroughly and try a short ride to see if you can pinpoint the leak.
If not, try taping a strip of paper towel over likely candidates, and when you peel it off you should be able to see which one has oil on it.
Old Feb 21, 2012 | 01:41 PM
jay956's Avatar
Good call.
Renderw
Jul 1, 2013 08:03 PM
98ILVTR
May 14, 2011 05:24 PM
E.Marquez
Feb 16, 2011 10:33 AM
VTRBandit
Feb 17, 2007 07:55 AM
enzo
Dec 7, 2006 03:42 PM
