To Rebuild Petcock Or Not?
Old Apr 2, 2011 | 08:39 PM
archaicguy's Avatar
That is the question!
When I went to remove my tank I pulled the fuel lines and it was a steady pour, I did not bother to turn the petcock off because I had read where it was vacuum operated. I then turned it off and still had a steady drip occuring. Now I have been riding it as it is and was just curious if it was something that I should buy a rebuild kit for soon or just wait till next winter?
Old Apr 2, 2011 | 09:07 PM
I'm not positive on this, but it won't be a problem unless you need to remove the lines from the tank. At least I did it a whole summer without knowing that gas wasn't supposed to pour down when I took the tank off.
Old Apr 2, 2011 | 10:25 PM
nykuryu's Avatar
nykuryu is on a distinguished road
so your still riding it with a leaking petcock? my figuring is if you can still start it and ride around it may not be that bad of a leak. that being said it may get worse and if it sits will seep past the rings and contaminate your oil.
Old Apr 2, 2011 | 11:39 PM
poppazuti's Avatar
Head Scratcher
The rebuild kit is like $30 and it takes maybe an hour (including pulling the tank and putting it back on). Doesn't really seem "winter project" worthy.
Old Apr 3, 2011 | 05:03 AM
archaicguy's Avatar
To me the problem seems so minimal that it would be a winter project or at least a 3day rain event seeing that I do have other projects such as a vehicle restoration that takes up most of my time.
I figure that since it is allowing fuel through it is acceptable, granted not ideal since it is originally designed to be vacuum operated, but still operational and much better than the opposite.
Old Apr 3, 2011 | 08:23 AM
As long as the float valves in your carbs are in good shape you shouldn't have a problem.
If one should happen to stick open things could get ugly, but it really isn't all that common for it to happen......
Old Apr 4, 2011 | 09:14 AM
search for gasoil on the forum read HawkRider's thread and see why a working petcock is a good thing..
Old Apr 4, 2011 | 10:05 AM
archaicguy's Avatar
Ok I read his thread and ordered the repair kit. The kit says
Note: Does not include plastic diaphragm spacer block
Is this something I will need or can I use the one on it?
Old Apr 4, 2011 | 10:10 AM
You can use the old one. It's a little plastic ring that attaches to two diaphragms- you just pull them out of it and put the new ones in.
Old Feb 23, 2012 | 06:41 PM
mertechperformance's Avatar
MandownMertech
where are you guys finding rebuild kits? my dealer tried to order k&l and it's back ordered for months. none in the usa so k&l said.
Old Feb 23, 2012 | 07:07 PM
spladle160's Avatar
I know it's a freak occurrence but if your petcock is bad and your floats don't seal and your stator is arcing things can get real interesting real quick.
Old Feb 24, 2012 | 06:07 AM
Bandit400man's Avatar
Bandit400man is on a distinguished road
I had to replace the petcock on my bandit cause the reserve wouldn't work...met a lot of nice people with gas cans trying to figure that one out lol
Old Feb 24, 2012 | 07:17 AM
This OEM part set should be all you need for a rebuild:
Part Number: 16953-ML0-034
Description: COVER SET, PETCOCK for Honda
It has all of the gaskets and such in there. Around 30 bucks.
The aftermarket ones are hit and miss for quality.
duc186
Aug 13, 2012 11:54 AM
trickedoutz
Mar 17, 2012 10:15 PM
archaicguy
Feb 23, 2012 06:47 PM
Mark Morrison
Aug 7, 2008 06:36 AM
skokievtr
Apr 5, 2008 10:12 AM
