Bad petcock rebuild kit
Old Apr 11, 2011 | 10:13 AM
archaicguy's Avatar
Stay away from this repair kit
Honda VTR1000 VTR 1000 Superhaw Fuel Petcock Repair Kit | eBay=
I got mine and both the diaphrams were undersize and unusable. The only items I used from it were the screws, spring and oring.
I was able to repair mine as the problem seemed to be a blockage on the vacuum inlet. It seemed that you could apply vacuum and it would open the diaphram to allow gas to flow but there was a blockage that would not allow a release in the vacuum so it would close. Mine works perfectly now so that was about 20 wasted dollars.
Just a heads up with my experience on this kit
Old Apr 11, 2011 | 10:50 AM
2armor's Avatar
2armor is on a distinguished road
Thanks for the info. Did your run at all before you decided to replace it? If it did run, what was going on with it?
I just pulled my diaphram () yesterday and all seams to be fine with it. I though for sure it had a crack since its a 99 but it appeared fine. On hard acceleration or 60+ mph it act like it running outta fuel.. I figured it was the diaphram not opening all the way. vaccum is good and the intank filter is yellow but looks like new.. Petcock is in full open and the vac hose is on the right nipple. I guess I need to pull the damn carbs and rebuild.. Or is the gremmlin in the ignition/coil/sparkplug...uhhhg.
Old Apr 11, 2011 | 11:03 AM
archaicguy's Avatar
Mine ran just fine. I didn't know anything was wrong till I removed my tank and when I pulled the fuel lines it was a freeflow.
Old Apr 11, 2011 | 11:17 AM
2armor's Avatar
I see, Thanks for the reply. Sounds like you had a return spring issue (unlikely) or the small diaphram side was torn or had a bad seat.
I was thinking (& hoping) mine was a tear in the vaccum side (larger side?) of my diaphram but it all seems good.
Time to trouble shoot and trace..
Old Apr 11, 2011 | 11:35 AM
archaicguy's Avatar
Luckily I checked the operation of it before I reinstalled it and found that the vacuum would not release, so a little air pressure to the vacuum hookup while disassembled seemed to work.
The vacuum side diaphram from the kit was too small in diameter and would not seal
and the small one was not tall enough and wouldn't even seat on the petcock side.
Old Apr 11, 2011 | 11:47 AM
2armor's Avatar
That sucks, I guess stick to OEM when the time comes.
Old Feb 23, 2012 | 06:47 PM
mertechperformance's Avatar
MandownMertech
where are you guys finding rebuild kits? my dealer tried to order k&l and it's back ordered for months. none in the usa so k&l said.
There is no oem kit just entire petcock replacement at approx $205.00
MotoHawk
Sep 30, 2013 12:54 PM
trickedoutz
Mar 17, 2012 10:15 PM
archaicguy
Feb 24, 2012 07:17 AM
Mark Morrison
Aug 7, 2008 06:36 AM
skokievtr
Apr 5, 2008 10:12 AM
