Rear Brake Pad Change - Pad Pin Stuck
Old Apr 29, 2015 | 07:46 PM
ReillyDoorn's Avatar
V-Twinning
ReillyDoorn is on a distinguished road
Hi, I was in the process of changing my shot rear brake pads. I got the caliper off, and then went for the pads. I couldn't seem to get the pad pin off. This is the one with a line through the pin head. Has anyone had trouble getting this off? Is it meant to be unscrewed or pushed out?
Edit: Also, just noticed the rear caliper looks like a vtwin, rad.
Attached Thumbnails Rear Brake Pad Change - Pad Pin Stuck-rear-caliper-vtr.jpg
Old Apr 29, 2015 | 07:51 PM
It just unscrews and the actual pin is underneath it.
Old Apr 29, 2015 | 07:53 PM
V-Twinning
Thanks, problem is, mine is totally seized. I'm afraid if I keep trying to turn it, it'll just strip the screw. Guess the best option here is to buy a new caliper?
Old Apr 29, 2015 | 07:56 PM
Cadbury64's Avatar
VTR virgin
These screw out, but like to seize in place and they're made of soft alloy so can be stripped easily. I'd use an impact screwdriver to get this loose, then use some copper-slip anti-seize when you re-install.
Old Apr 29, 2015 | 08:30 PM
thedeatons's Avatar
I use the hand impact driver also.
James
Old Apr 30, 2015 | 01:28 AM
Wicky's Avatar
Sometimes it needs dremmelling - once out replace with a stainless hex head grub screw and copperslip.
https://www.superhawkforum.com/forum...er-caps-33003/
ohiophotog
Mar 26, 2015 04:50 PM
ProfChaos
Dec 29, 2011 03:25 PM
Crashrat
Dec 13, 2009 07:17 AM
CNI Dawg
Nov 6, 2005 06:59 PM
mamisano
Apr 3, 2005 12:41 AM
