Rear axle spools
Does anyone here use axle spools the ones that just slip into axle holes while using rear stand to clean chain.
I just slide a 5/16" steel rod about 24" long thru the hollow axle.
If this works for you too, mark the ends with a bright color so you don't forget to take it out when you're done. |
Spools
Thanks that will be good enough for cleaning chain.
Spools
I tried the rod didn't work my stand to short to lift tire off ground.
