Rattling noise from rear cylinder at idle
Old Aug 8, 2014 | 04:43 PM
outrigger's Avatar
outrigger is on a distinguished road
Morning all,
I had my bike out last night for a run to town for dinner. It's been garaged mostly the last couple of months because it's cold and I'm soft. When I do get it out it starts fine, warms up reasonably quickly and runs well (this is all past tense...). On the way home last night I pulled up at the lights and heard a rattling sort of noise that seemed to be coming from the rear cylinder. Only at idle, and maybe very low revs (<1800rpm). Still makes the noise if I clutch in at speed. No noise when accelerating, cruising or engine braking. I ride with plugs in and anything I can hear over the exhaust is significant, so it's not subtle.
For the record, Kreiger mCCTs went in when I got the bike at 70,000km (now at 90,000) and I'm running old style 2bros exhausts. Recently did an oil and filter change with Motul 5100 10W/40.
Power does not seem affected at the low end - I didn't rev high on the way home with the noise because I didn't want to blow anything up, took it easy. Next weekend I will try pulling the valve cover and see what I can see. In thw meantime, any lightbulbs? CCT was my first thought but (a) they can't really fail, it hasn't moved from position and (b) no power loss or grenading.
Thanks team
Old Aug 8, 2014 | 05:41 PM
thetophatflash's Avatar
Exhaust leak? How "heavy" is the sound?
Old Aug 8, 2014 | 06:00 PM
jerryh's Avatar
Time to adjust mcct?
zxbud's Avatar
Maybe the mcct locknut backed off
Old Aug 8, 2014 | 06:26 PM
CrankenFine's Avatar
I agree it's worth pulling the valve cover and inspecting for proper chain tension - the MCCT can't fail but the tensioner assembly it pushes against may have changed or deteriorated. But hopefully nothing more than some loose exhaust parts. Hope all's well once determined.
Old Aug 8, 2014 | 06:32 PM
outrigger's Avatar
Doesn't sound like exhaust, but I admit I cannot entirely rule it out. Sounded to me like something loose, but I hear that exhaust catches people that way
could be, but this came on quite suddenly, no build-up
it was still in place when I checked it at the servo, but can't rule it out so I'll re-tension front and rear to spec
Hopefully something simple like that, or exhaust. Seemed too loud to be an exhaust leak but saying that I've never had one
Old Aug 8, 2014 | 06:35 PM
I was thinking more like loose clamps, loose retainer at head, possibly metal fatigue crack leading to vibration (rattle)
Old Aug 8, 2014 | 07:42 PM
outrigger's Avatar
It seemed like too deep of a noise to be that sort of vibe, i got a feeling of a bigger part, or more movement
Old Aug 9, 2014 | 01:41 AM
shadow623_'s Avatar
Newbie to the *****
shadow623_ is on a distinguished road
i can relate to this. mine only makes that rattle when its cold though. once im warm it sounds awesome.
Old Aug 11, 2014 | 01:27 AM
outrigger's Avatar
Any other thoughts about what I should hunt for?
Old Aug 11, 2014 | 05:32 PM
You have MCCT with 20k on them. As Jerry suggested maybe it time for an adjustment. What doesn't fit is the sudden onset of the sound. If it were me I would dump the oil in a very clean pan (that way you can reuse if nothing shows up). Drain it through a screened funnel and look for pieces of the tensioner. CAM CHAIN TENSIONER #3
Maybe the MCCT was set too tight and the tensioner has partially failed . I know it's unlikely but I wouldn't run the bike until I solved the issue. Did the sound start on the first ride after the oil change?
Old Aug 11, 2014 | 05:49 PM
jerryh's Avatar
Change the oil filter too and open up the old one. I've heard of defective oil filters causing low pressure (rattling)
Old Aug 12, 2014 | 12:04 AM
outrigger's Avatar
Cheers Xeris, yeah I was thinking the suddenness was off. Thanks for the fiche link, hadn't' really looked at the guts of it before. I'll give the pan a good wipe and dump the oil through a steel sieve.
Noise started about 400km (?) after recent oil change, third or fourth ride.
Thanks jerryh. I usually do the filter every second change (so about 10,000km/6,000mi), so it's done 5,400 odd km without issue, but a $10 filter is good insurance, specially if its gonna be full of bits of tensioner
Old Aug 12, 2014 | 03:14 PM
Troy Wallis's Avatar
Troy Wallis is on a distinguished road
Keep us posted on this please. Sounds kinda like the noise I'm having. No loss of power or anything. Just a rattle noise in the rear cylinder at low rpms.
Old Aug 14, 2014 | 04:47 AM
outrigger's Avatar
Ok I pulled the rear cam cover tonight to see what I could see. Everything looked fine, tensioner blade seems intact, tension adjuster not significantly moved. I re-tensioned front and rear mCCTs. Exhaust manifold (rear) also seems very snug, no movement. Can't rule out slight leak I guess, but I'm iffy about that, didn't sound anything like exhaust. So nothing to show for a few hours work. I'll fire it up on the weekend, I don't live in the sort of neighbourhood where cranking the two-brothers at 9.30 goes down well on a weeknight. I will record a video, too, and see if I can pinpoint the nosie
Old Aug 15, 2014 | 01:53 AM
outrigger's Avatar
Started the bike this arvo. Who can guess what I'm going to say...?
No noise. I'll have to come back to this one, this thread isn't dead yet...
Old Aug 15, 2014 | 02:39 PM
jerryh's Avatar
You fixed it...good job!
clac
Aug 24, 2011 09:49 PM
jmcollins77
Jun 22, 2011 03:54 PM
zwoehr
Feb 17, 2011 09:07 AM
MarineHawk
Oct 29, 2007 10:33 PM
fromanoc
Sep 8, 2007 07:04 PM
