Random Vaccum Hose from Rear Carb
Old May 12, 2015 | 12:17 PM
bewsted's Avatar
bewsted is on a distinguished road
So when installing my shift light and gear indicator I decided to check my intake setup out and do a little snooping around the bike.
Upon inspection I found a random vacuum hose that comes off the rear carb that was lieing disconnected.
The line off the front carb goes to the petcock and I looked everywhere and cannot find where this vacuum line might need to be.
Old May 12, 2015 | 12:26 PM
The correct routing is that line goes to the petcock and the front line should be plugged.
Old May 12, 2015 | 12:54 PM
Hangfly's Avatar
And can be used for "syncing" the carbs when needed. I believe.
Old May 12, 2015 | 01:50 PM
bewsted's Avatar
So i should switch them then huh
Old May 12, 2015 | 01:55 PM
You don't really have to but that is how it is run stock.
Just run one to the petcock and plug the other (to use when you sync the carbs)
Old May 12, 2015 | 01:58 PM
bewsted's Avatar
Gotcha....Same amount of vacuum from both i presume?
Old May 12, 2015 | 02:10 PM
bewsted's Avatar
Well plugging that certainly changed the idle of the bike LOL
Old May 12, 2015 | 03:36 PM
You will also notice A LOT less popping from the exhaust on deceleration with that plugged.
thedeatons
Apr 1, 2015 01:49 PM
bpw
Nov 26, 2013 10:16 AM
zbart1108
May 27, 2012 07:23 PM
fred
Apr 20, 2011 11:30 AM
SuperBlink
Mar 13, 2011 08:46 PM
