Random Vaccum Hose from Rear Carb
So when installing my shift light and gear indicator I decided to check my intake setup out and do a little snooping around the bike.
Upon inspection I found a random vacuum hose that comes off the rear carb that was lieing disconnected. The line off the front carb goes to the petcock and I looked everywhere and cannot find where this vacuum line might need to be. |
The correct routing is that line goes to the petcock and the front line should be plugged. ;)
Originally Posted by 8541Hawk
(Post 386046)
And can be used for "syncing" the carbs when needed. I believe. |
So i should switch them then huh
Originally Posted by bewsted
(Post 386057)
Just run one to the petcock and plug the other (to use when you sync the carbs) |
Gotcha....Same amount of vacuum from both i presume?
Well plugging that certainly changed the idle of the bike LOL
(Post 386061)
