Radiator Fan question
Old 07-05-2009, 02:55 PM
I don't need any Meds
5150's Avatar
5150 is on a distinguished road
I pulled a rock out of my fan that had jammed it. i replaced the fan fuse as it was blown.
now i have a question. the fan still does not come on at any temp. i can freely spin the fan by hand. should i be able to? is this a clutch engaged fan and spins free when not engaged or is this a fan that should not spin when not powered?
5150 is offline
Old 07-05-2009, 03:48 PM
Couple things might have happened. The motor spun the shaft or if the shaft didn't spin it might have killed the motor. Either way it's got to come out. It's a PITA if you do it with the cowling in place but it can be done.
nuhawk is offline
Old 07-05-2009, 03:54 PM
5150's Avatar
ok. so the fan should not free hand spin like it is now once the jamming item has been removed?
5150 is offline
Old 07-05-2009, 04:01 PM
johnclopp85's Avatar
johnclopp85 is on a distinguished road
Not sure if the fan should spin freely, but I am willing to bet the electric motor is shoot. Electric motors need to run in order to keep themselves from over heating, and with a rock jammed the engine was trying to spin but couldn't.
johnclopp85 is offline
Old 07-05-2009, 04:08 PM
Red_Liner740's Avatar
yea, it will still spin freely even if its fine...mine does and i know my fan works...
take it off, bring it to 12V battery and directly engage the contacts, see if spins up
Red_Liner740 is offline
Old 07-05-2009, 04:19 PM
5150's Avatar
sounds like a plan. will do thanks.
5150 is offline
Old 07-05-2009, 04:22 PM
5150's Avatar
1 more question. for us old school year 98 temp gauge hawk owners..at what portion should the fan kick in. i mean it should come on before the red line on the temp gauge right?
5150 is offline
Old 07-05-2009, 04:38 PM
Mine comes on when the needle points straight ahead or up. This is also about the time my inner thighs feel like they're being prepared for dinner. Parts of the nursery hit 113.5F this afternoon. It's only July, it will be nice in August. I was out on my Superhawk today. It was hot in traffic and I was back at 1300 - the real heat set in after I was back. Hot weather underwear and good mesh really help beat the heat.
nuhawk is offline
Old 07-05-2009, 04:42 PM
5150's Avatar
Good deal. thanks. yeah even right before red mine is not kicking in, i just wanted to make sure before i tear off the fairing and all to get the fan out that it did not need to be any hotter for the fan to start doing its thing.
lol and hot weather underwear? wtf is that? they have a place to slide in a frozen gel pack or some thing?
5150 is offline
Old 07-05-2009, 04:47 PM
on my hawk the fan engages just past the half way point....
Old 07-05-2009, 05:17 PM
5150's Avatar
ok that makes two of you then. enough for me to pull it all apart then. just didnt want to pull it apart and find out it comes on like at the red. mine has been up over 3/4ths on the gauge like right under red and nothing happens.
i will pull it and put power to it since that is a great suggestion and first place to start before moving on to other areas of the bike. thank you all for the suggestions and the info on how yours performs.
50
5150 is offline
Old 07-05-2009, 05:26 PM
guru of things sparky
Circuit_Burner's Avatar
+1
Its pretty straight forward, its a light armature DC motor with very little mechanical resistance. If it blew the fan circuit fuse, its very possible the small-guage windings have burned open somewhere in the motor.
Circuit_Burner is offline
Old 07-05-2009, 05:32 PM
5150's Avatar
+1
Thank you CB i always appreciate your insight into things sparky. you always have good insight into these areas. i love to know how things work so thank you for the mental image of the fan internals.
5150 is offline
Old 07-05-2009, 05:34 PM
5150's Avatar
ahh hey CB curiosity on my part but..if the winding internally are small and they burn at and around the same time as the stock 10 amp fuse.. would it be wise to drop down to say maybe a 5 amp if this does happen to be true that the windings did in fact burn?
5150 is offline
Old 07-05-2009, 05:43 PM
Well, that would only verify anything if the windings were still a closed circuit.
If the windings have burned open, it will have zero current draw, and wouldnt even blow a .5 amp fuse.
But I see the logic.
Old 07-05-2009, 06:11 PM
5150's Avatar
ohh no i meant in the future for a new fan. what fuse size in your opinion would absolutely blow before any fan damage would occur to the windings?
5150 is offline
Old 07-05-2009, 06:19 PM
The engineers had the rating right, 10 amps is fine.
A physically blocked fan is going to be trouble no matter what.
Going to a 5 amp fuse in case of more rocks, would be a solution, but you increase the chance of blowing the fuse in normal (non rock) conditions.
I dont think the benfit there would outweigh the safety of normal fan operation.
Old 07-05-2009, 06:23 PM
5150's Avatar
in my best mr. mackey voice impression.. mmmmmmk noted.
5150 is offline
Old 07-05-2009, 07:45 PM
kai ju's Avatar
The fan amp draw can reach as high as 14-15 amps on start up and then usually settles down to 4-5 amps.
A 10 amp fuse doesn't blow untill it's exposed to that load for more than a second.
Kai Ju
kai ju is offline
Old 07-05-2009, 10:25 PM
The fuse should blow before the motor burns up. That's the whole point of it being there. Check to make sure the fuse hasn't blown again, and that you have good continuity across the fuse you put in.
Hawkrider is offline
Old 07-07-2009, 03:25 PM
5150's Avatar
ok problem fixed but not found.
i pulled off the fairing's removed the fan and housing and took it down to have it tested. fan works.
i go home check the fuse to see if it has blown again and it had not, so i swap the 10 amp starter fuse and the 10 amp fan fuse(because i know the bike starts so that fuse is good for sure) and reassemble. i also notice the wire on the radiator sensor was stressed to the max and cracked open at the rubber boot housing. i turned it over and routed it for a little bit of slack.
i kick the bike over and watch it warm. and like clock work she kicks on at just above the 1/2 way line. so either i had a loose/dirty connection or a gremlin in the fan. either way problem solved for now.
Thank you all for the help and suggestions. and i am glad it was minor. but i have to say the fairing removal is a real pain in the ***. well not the take off but the putting it back. uhhhggg so much easier if i had a second set of hands for it. i am missing some of trim clips underneath the light that pin it together and give stability, and it was very floppy.
50
5150 is offline
BIG DAVE 03
07-07-2012 11:55 AM
Radiaoktiv
12-19-2007 09:24 AM
2sonrk
08-24-2006 03:41 PM
cat0020
06-06-2006 04:33 AM
inderocker
06-23-2005 10:54 PM
Quick Reply: Radiator Fan question
