Question about pulse generators.
Old May 2, 2011 | 05:05 PM
bass4dude's Avatar
bass4dude is on a distinguished road
First and foremost, thanks Mike for coming down and looking at my sick SH. You certainly pointed me in the right direction.
Now to my question, is the center pole on the pulse generator supposed to be grounded to the mounting tabs inside the case?
If it is then someone explain to me how this creates a pulse, please =)
Old May 3, 2011 | 08:58 AM
No problem..... Hope you get it figured out soon.
Old May 4, 2011 | 12:35 PM
bass4dude's Avatar
It doesn't show that it is on the wiring diagram so someone with a set laying around wanna check for me PLEASE! and thank you!
Old May 4, 2011 | 12:46 PM
RCVTR's Avatar
Are you talking about the crank angle sensor / pulse generator?
It's just an electrode surrounded by plastic, right? It is not connected to ground. That would be a short.
Maybe I don't understand the question...
Old May 4, 2011 | 01:17 PM
bass4dude's Avatar
Pulse generator pictured and I have cont. from center pole to ground.
Logic tells me that this is a simple electromagnetic coil pickup, and therefore, when the center post passes over the 3/4 disk with the pickup points on it, it makes a current (.7v according to service manual) then gets sent to ecu/ICM, gets bumped up to 100+V, sent to coils, and it's spun up to sparking voltage.
But if the center pole is grounded (shorted) then the 0.7v would just get sent to ground instead of ecu/icm and stopping the entire process.
I'm just posting to double check my logic here because I've sunk too much money into this problem as is.
Old May 4, 2011 | 01:21 PM
It would make sense with the problem you are having.
Though we need Tweety to show up and tell us the answer......
I'll pull out my wiring diagram to see what I can find but I really don't think it should go to ground there.
Old May 4, 2011 | 01:34 PM
It makes sense here as the bike just stopped running and I have checked everything in the system and even installed his ECU and converter on my bike to prove that they are good. The only part that hasn't been checked or replaced with a known good part ( I swapped the coils also) is the pulse generator.
So that's as far as I got. Now he is just trying to prove the part good or bad before buying yet another replacement part.
Old May 4, 2011 | 01:36 PM
Wait, I think I have an extra one of those... what should I test to make sure it works?
Old May 4, 2011 | 01:37 PM
Then I can send it to you if you'd like.
Old May 4, 2011 | 01:50 PM
I have continuity between everything on mine- not sure if it works or not as I never had it on the bike...
Old May 4, 2011 | 02:00 PM
RCVTR's Avatar
I see what you mean. It's probably a coil, in which case it will have continuity to ground.
to test it, you need to measure the peak output voltage, while cranking the engine.
On an RC51 the peak output voltage is 0.7V minimum. check your manual for the VTR. You'll need a high impedence digital multimeter (10Mohm/DCV).
Old May 4, 2011 | 05:17 PM
bass4dude's Avatar
That's what I don't get because there should be a circuit, not the live pole grounded. I know that in order for there to be a voltage, there has to be both ground and live (in a DC system at least).
So the way that I'm looking at it, is that the center pole is what is creating the charge, so if that is also grounded, that completes the circuit because the electricity will find the easiest way to ground, and that would be inherently, through the case it is mounted too.
And I built a peak voltage tester.... kinda (used a capacitor and diode), and I didn't register any spark despite having it set up correctly. I don't think that there's any other way to test it. Unless I could use a low voltage LED and just use that as a signal checker and not necessarily as a peak.
To recap what's been checked:
  • Entire ignition wiring (according to wiring diagram: checked resistance and continuity)
  • Switches
  • Coils
  • Sparkplugs
  • ECU/ICM (thanks once again mike) I have 2 working sets
that leaves nothing in the ignition system but the pulse generators.
And I just looked at the connector side of the unit, and it appears that I don't have continuity between either of the wires in the connector or anywhere on the pickup post.
If you've removed every wrong answer, the only solution left is the right one.
It is an electric part, so it hypothetically could have just shat the bed. Wouldn't be the first time I've seen a fluke like that.
But Tweety, if you're out there, some input would be awesome =)
Old May 5, 2011 | 01:00 AM
Ok, I'm awake now... Mike poked me with a stick...
I couldn't make heads or tails of it either at first glance, so since I'm swapping oil this afternoon, I'm going to measure mine... Be back in a few hours with more...
Old May 5, 2011 | 08:29 AM
RCVTR's Avatar
Electricity.
You can't see it.
Significant dosages can be fatal.
The rest is a mystery...
Old May 5, 2011 | 08:31 AM
Seriously, I'll send you my extra one to see if it makes any difference!
Old May 5, 2011 | 09:09 AM
bass4dude's Avatar
I've got a dealer over here who owes me a favor, so I'll contact him, and if I can't get anything from him I'll go ahead and let you know.
If not I might just order OEM somewhere online just to go with something known good with zero miles haha. Most longevity for the money =)
Old May 5, 2011 | 09:50 AM
Well, my working one isn't grounded to the pin... So that kind of starts the next line of questions... Can't really tell you more than that though, or at least nothing that hasn't already been said by the rest of you guys...
Old May 5, 2011 | 11:37 AM
bass4dude's Avatar
Looks like I get to pull the dremel tool out and cut this puppy open to see what it looks like on the inside *insert maniacal laugh* BWAHAHAHAHAHAHAHA.
But thanks for all the input guys, I'm gonna order the parts today and hopefully we shall have joyous noise when I get the parts!
Old May 5, 2011 | 11:50 AM
Thanks for checking...... you know this electrical stuff is still all FM to me.... but I could find nothing else wrong with my basic troubleshooting skills.
Little_Horse
Sep 10, 2012 07:35 AM
superbeater
May 26, 2009 05:11 AM
Reb
Sep 10, 2008 01:37 PM
98VTR
Aug 27, 2006 04:22 PM
motherbelgium
Jul 14, 2005 10:57 AM
