quick cct ?
Old May 2, 2011 | 06:02 PM
smk2mch87's Avatar
smk2mch87 is on a distinguished road
quick cct ?
ok when im lining up ft and rt marks, i line up the line under with the line in the threads right? dont wanna be off n cause bs. just picked up my krieger tensioners today n theyll be in tomorrow
Old May 2, 2011 | 06:35 PM
nykuryu's Avatar
nykuryu is on a distinguished road
ya line up the line under FT RT with the little line where the tiny cap went.
Old May 2, 2011 | 07:11 PM
smk2mch87's Avatar
k thats what i thought just wanted to double check, thx pimpin
Old May 2, 2011 | 07:13 PM
smk2mch87's Avatar
u guys ever pull the plugs to get less compression when turning the wheel?
Old May 2, 2011 | 07:26 PM
nykuryu's Avatar
i use a breaker bar on the crank bolt under the big plug right next to the little plug
Old May 2, 2011 | 07:33 PM
smk2mch87's Avatar
ok, i just talked to the guy i picked up the cct's from n he said to pull the front plug when doing the rear n the rear when doing the front n itll make it a hell of a lot easier to spin
Old May 2, 2011 | 07:45 PM
nykuryu's Avatar
ya if your just using the wheel it will make it a lot easier. just takem both out.
Old May 5, 2011 | 01:29 PM
klx678's Avatar
Just hangin' out
klx678 is on a distinguished road
My thought was if you want the cylinder on TDC, pull the plug on the cylinder you are NOT doing, that way while turning the engine, when it comes up on compression it will HAVE to be the one you are doing. Then do the same for the other cylinder. I'm thinking this may keep from having the cam chain skip the way people have said it could.
I'm still waiting for some feedback from some of the people who've gotten the tensioners. I've got all six sets I had cut are out there and only SMK has been in contact. I'm kind of figuring no news is good news. If they didn't work I'd be hearing about it. That or everyone is not riding. I have another batch being cut, so it's going to be about a week for them to show up for me to finish.
I just sent a set out for a Vulcan 1500 and I've gotten feedback in two days. Good feedback on the first one we've done. It may need a slightly longer bolt is all. Like I said, they're all similar in what they do and how they work.
I am looking to hear from someone soon. I know SMK will be in touch, but he may have engine damage from the failure of the stock ones. He and I figure why not try the manual units before teardown in hopes that he didn't trash any valves. It's worth a try.
Tebs
Sep 4, 2012 03:06 PM
uchi
Apr 11, 2011 06:19 PM
rich.m
May 25, 2010 11:29 AM
ima98chickenhawk
Oct 29, 2009 02:51 PM
SlowHAWK
Jun 9, 2006 09:38 AM
