Q for Hawkrider and others with 1000RR experience
Old Dec 6, 2007 | 12:26 PM
It seems I'm having a hard time finding a complete triple tree for a 929/954RR, I have a top triple, but no lower...
So, since I got a full triple tree with my forks I might just use that instead... It's in transit right now so I can't really measure it...
Would anyone know if the dimension of the steering stem from the 1000RR matches that of the VTR and 929/954RR? Will it be possible to use the same bearings? (i'm most likely ordering tapered one's...)
And It also seems I have the same problem as GregW... I have a 04-05 fork and 06-07 rotors... As far as I can tell, the only difference is that the newer fork uses spacers on the caliper bolts...
Is this correct, and if so where can I get them? I can see them in the Ron Ayers microfiches I think, but no Part# for them... I really don't want to go down to the Honda center around here... They charge ridiculous amounts for just about everything...
Old Dec 6, 2007 | 12:55 PM
reaper's Avatar
Tweety:
Here is a complete front end for the 954RR on Ebay, http://cgi.ebay.com/ebaymotors/2003-...QQcmdZViewItem
and another
http://cgi.ebay.com/ebaymotors/02-HO...QQcmdZViewItem
Old Dec 6, 2007 | 01:00 PM
Well... yeah... but I already got the 1000RR forks...
And in all honesty I like them better... Radial calipers...
Old Dec 6, 2007 | 01:10 PM
superbling's Avatar
I
Would anyone know if the dimension of the steering stem from the 1000RR matches that of the VTR and 929/954RR? Will it be possible to use the same bearings? (i'm most likely ordering tapered one's...)(
Go to allballsracing.com and see if they take the same bearing part number. That should answer your diameter question but not the stem length measurement.
Old Dec 6, 2007 | 01:11 PM
reaper's Avatar
Here a 929 complete triple tree, http://cgi.ebay.com/ebaymotors/HONDA...QQcmdZViewItem
Old Dec 6, 2007 | 01:15 PM
Oh, good...
Why can't people agree on one spelling? triple/tripple... dangit...
Old Dec 6, 2007 | 08:51 PM
Gregw's Avatar
Hi Tweety,
I’m learning as I go, so I’m no expert. Greg (HawkRider) clued me in on the ’06 caliper spacers and using the ’06 flange bolts (caliper to fork), which are longer than the ’04 flange bolts. I bought my stuff from http://www.partspitstop.com
Part #’s
Flange bolt (10x62): 90131-MEL-D20
Spacer, Front Fork: 51497-MEL-D20
Old Dec 7, 2007 | 02:40 AM
Originally Posted by Gregw
Hi Tweety,
Part #’s
That makes two of us...
Do you know if that is a pair or single item ( I doubt it's 2 pairs...) guessing single item thoo...
Old Dec 7, 2007 | 06:16 AM
Gregw's Avatar
You’d think at $7.77 you’d get more than one bolt, but no. You need to enter 4 in the quantity box for both parts, at least for this parts supplier.
Old Dec 10, 2007 | 05:39 PM
The 1000RR fork spacing is 2mm wider than the 929/954. Mix and match of upper and lower triples will not work. It takes a while - took me 5 months of collecting parts. I was being picky. I found the upper triple was more difficult to find than the lower triple.
Old Dec 10, 2007 | 05:50 PM
drew_c14's Avatar
This may be a little out of my league...
How much is involved in doing a swap to a 954 front end? Obviously need the forks, trees, stem, axle, rim, etc.
Is it something where I could just buy the parts and slap it on in a weekend?
Old Dec 10, 2007 | 05:52 PM
Well, I wasn't thinking of mixing them... I have a upper 929/954, but no lower... I found the upper ridiculously easy & cheap, and it was in mint condition when it arrived too... A lower however seems worth it's weight in gold?
I also got a FULL 1000RR triple tree with new unmounted bearing with the forks... unfortunately since Swedish customs are slower than drying paint it's still not arrived... (I think they like large boxes... Last time I had a full set of fairings shipped it arrived with the inspection stickers of three (3!) swedish customs officials... As far as I know Sweden only has one border? )
So the question was if that steering stem would match the frame?
Old Dec 10, 2007 | 05:57 PM
Oh and yeah... I still haven't bought a lot of other parts yet... I'm also being picky...
But as I can swap the steering stem and then put her down on the front stand which lifts in the stem and keep working on her during the winter that isn't a problem, IF I can get the parts needed for that...
I have to be picky, even if I find mint stuff att ridiculous low prices the shipping across the pond will account for half my tab... (And it will still be lower than getting this stuff localy, new OR used...)
Old Dec 10, 2007 | 06:02 PM
I have seem complete 954 front ends on ebay... including allmost all you need (brakes etc)... Ususally you just need to add the rim/wheel... Getting a complete set like that would have killed my budget combined with shipping, but for you being in the US, that would probably be easy...
Old Dec 10, 2007 | 06:07 PM
http://cgi.ebay.com/ebaymotors/2006-...QQcmdZViewItem
Here is a full 1000RR fork sans the other parts... would probably be a great start...
Old Dec 10, 2007 | 06:13 PM
Oh... There really shouldn't be to much modification work... And the parts there is seems to have been covered rather well by others including Greg...
Main parts would be moving the radiators and getting the steering stops working... plus the fun task of removing/re-installing bearings...
Oh... and the really fun part comes when you fork out for the Helibars...
Old Dec 10, 2007 | 06:15 PM
drew_c14's Avatar
how far do you have to move the rads?
Old Dec 10, 2007 | 06:24 PM
I think people quoted 3/4" ?
See here for a rather detailed description of how to do it nicely...
https://www.superhawkforum.com/forum...ad.php?t=13355
Old Dec 10, 2007 | 06:28 PM
Keep in mind I haven't done this yet... I'm still collecting parts and information myself...
But I'm rather confident that if I had all the needed parts before hand I would easliy do the bulk of the work over a weekend...
Now over here we had 8" of white stuff last night... So I'm glad to leave the bike in the warm and cosy workshop without getting impatient...
E.Marquez
Apr 13, 2014 08:10 AM
Appletonhawk
Feb 11, 2014 11:22 AM
Jun 6, 2011 04:19 AM
Billzilla15
Oct 29, 2009 11:59 AM
Liquidogged
Apr 25, 2009 09:09 PM
