Pulling the Alternator flywheel
Old Sep 23, 2006 | 04:23 PM
Mick-e's Avatar
Mick-e is on a distinguished road
Has anyone done it on the SH?
I need to purchase the flywheel holder, and puller and I was wondering if anyone could recomend where to buy the tools.
Thanks
-Mickey
Old Sep 23, 2006 | 04:30 PM
Thanks
-Mickey
Try http://www.motionpro.com/ I do not see one listed on the web site,, but do know they have more tools then what they list.
Old Sep 28, 2006 | 04:25 AM
shayne's Avatar
It is an interference fit, so watch it when you pull it off. They can come off with a bang and take ten years off your life span!!
Old Sep 30, 2006 | 12:43 AM
RCVTR's Avatar
The puller's not very expensive from Honda. Maybe $35. then you'll have it in our toolbox. Works on other engines too. I use a dead-blow hammer. A couple gentle knocks and it's loose. You can use a shop rag to jam the primary drive gears (on the other side of the engine), but it's not really necessary on the flywheel. there's enough inertia and friction there to loosen it with just a dead blow.
Old Sep 30, 2006 | 06:18 AM
Part Number: 07933-3290001
Description PULLER DYNAMO
Price $7.16
Old Sep 30, 2006 | 11:16 AM
RCVTR's Avatar
Wow, that's way cheaper than I remembered. Lost in a pile of engine part purchases.
You will need to pull the right cover off and jam the primary gears to remove the bolt. The torque on it is quite high. Make sure you retorque it properly. Very important on a taper fit.
Old Sep 30, 2006 | 02:17 PM
shayne's Avatar
Hey RC, why not just put it in gear and hit it with an air rattle gun? That is what I did and the nut came off easily with no undue load on the gearbox. That would be much easier than removing the clutch cover.
It has been a long time since I removed mine, am I forgetting something?
Old Sep 30, 2006 | 03:58 PM
Skip the trans in gear. Using a good air gun, that nut will come off every time.. And if you ask a dozen older techs ,,, and they don't lie to you... You'll find they do it the same way...
Old Sep 30, 2006 | 04:51 PM
RCVTR's Avatar
Sounds good. That's how I take the clutch off.
I personally like the idea of using a torque wrench to reinstall though. And you'll have to prevent the engine from turning to do that. I'm sure lots of techs don't worry about it and just gun it tight.
I was doing the whole motor when I did mine.
Old Sep 30, 2006 | 09:05 PM
shayne's Avatar
Yeah, torquing it back up again was a bit of a mission. I had it in gear for that. I didn't need to do that to remove it with the rattle gun.
Old Oct 2, 2006 | 01:21 PM
Mick-e's Avatar
Well, using a rattle gun is how I get the flywheel off my EX500 racer, but I tried it on this and it didn't work. I do have a 1/2 drive gun that I could try, but I need a 1/2 drive socket.
That's probably worht a try.
Old Oct 16, 2006 | 06:18 PM
Mick-e's Avatar
make that a 3/4" drive, and it came right off.
Now I need to get the damn flywheel off.
Old Nov 5, 2006 | 03:35 PM
Mick-e's Avatar
After I bought the $7 Honda tool the flywheel came right off.
When I pulled the starter wheel off the back of the flywheel the sprag clutch literally fell off in pieces.
I'm attaching a photo of the assembled pieces.
After putting in a new sprag clutch, and bolting everything back on the bike started right up.
I live in the city, and this bike is my daily commuter so it's hard to say how many times I've started the engine but I bet it's a lot more than most bikes with 60,000+ miles.
So to those of you with high mileage bikes if you start to hear a "crunchy" sound when you hit the starter button it's time to change the sprag clutch.
-Mickey
now it's time to swap those carbs, but that's for another thread!
3amta3
Sep 28, 2011 06:32 PM
Sgt Rock
Apr 22, 2008 05:30 AM
radbikers
Feb 6, 2008 06:59 PM
redman
Aug 22, 2007 08:34 PM
