Stupid ? How to adjust rear shock damping
Old Nov 3, 2006 | 12:00 PM
B R's Avatar
B R
B R is on a distinguished road
I know where it's located, & that I have to turn the screw, I'm not that stupid, I read the manual . The problem I'm having, is getting a flat blade to mate up with the screw . What am I doing wrong? A big long screwdriver wont make friends, the swingarm and/or pipe get in the way. I tried a little stubby, in from above, but that wouldn't fit. So what's the secret? Special tool needed, like a rubber screwdriver?
Old Nov 3, 2006 | 02:01 PM
Scooberhawk's Avatar
Seņor Miembro, Ay Caramba
I've never had an issue making a standard 10" flat-head screwdriver work.
Old Nov 3, 2006 | 04:36 PM
JamieDaugherty's Avatar
Yeah, a standard screwdriver fits just fine. The screw has S and H marks with a circular arrow near the screw. Make sure the screw you are trying to adjust has these markings near it.
Old Nov 3, 2006 | 07:26 PM
superbling's Avatar
It has damping? ROTFLMAO!
Old Nov 3, 2006 | 08:25 PM
B R's Avatar
B R
Ok, I went back & tried it again. I'm close, but still can't do it. I think I know why. The screwdriver is hitting against the bolt on the pipe clamp. I suspect that it's the orientation of that bolt that's working against me. In other words, if I loosen the clamp, & rotate it a little, I can get the bolt out of the way, & then I can probably barely connect .
Old Nov 4, 2006 | 12:37 AM
B R's Avatar
B R
Ok, I take it back, I am that stupid. So I loosened up the pipe clamp, spun it around & then I could just get my screwdriver on the screw. But then when I tried to turn the screw, guess what? I wouldn't turn. I was really getting pissed at this point & thought, let me look on the other side(right). There it was, a tiny little screw, easily accessed, & easy to turn. All this time I had been working on the left side, with a screw that doesn't even turn !
No more comments are needed at this point. Thank you.
Old Nov 4, 2006 | 01:34 AM
Aw, but what if we want to poke fun at you? Can I comment then? hehe
Don't worry. You're probably not the first, nor will you be the last.
Old Nov 4, 2006 | 04:25 PM
Superbling - The technical term IS damping, 'dampening' is not really correct.
Old Nov 4, 2006 | 07:17 PM
Randman's Avatar
Moderate-whore
I'll poke fun as it is very rare that I get to make fun of someone else, I am usually the moooooron screwing things up, so ha I am not alone...
at least you figured it out...good timess....
Old Nov 5, 2006 | 01:37 AM
swordfish's Avatar
first time I went to adjust mine I did the exact same thing. wrong screw. don't feel too bad.
Old Nov 6, 2006 | 09:56 AM
blokeontheend's Avatar
blokeontheend
Talking
...I tried a little stubby, in from above, but that wouldn't fit. So what's the secret? Special tool needed, like a rubber screwdriver?
are we talking bikes or chicks here ?
Old Nov 8, 2006 | 11:38 PM
Loco's Avatar
Loco
Neither one is really very receptive to a rubber screwdriver.
dshakes
Apr 26, 2010 05:34 PM
htwin
Apr 22, 2009 07:44 PM
EngineNoO9
Nov 4, 2006 01:25 AM
Jaedcem
Aug 30, 2006 11:10 AM
faz
Apr 21, 2005 12:33 PM
