possible tank leak...is filling with H2O a bad idea?
Old May 11, 2008 | 09:30 AM
andy9743's Avatar
i have what i think is a small gas leak coming form my tank. thought it was the sending unit or gasket under but i do not think that is the culprit. thought about filling tank with water off the bike to see if i could get to the bottom of it. any ideas/suggestions? it's definately coming from under the tank and running down the tank to the frame (tank was spray painted so i'm thinking it was picking up paint as it went). see pics.
thanks
andy
Attached Thumbnails possible tank leak...is filling with H2O a bad idea?-2008_0330friedrr0024.jpg   possible tank leak...is filling with H2O a bad idea?-2008_0330friedrr0025.jpg   possible tank leak...is filling with H2O a bad idea?-2008_0330friedrr0032.jpg   possible tank leak...is filling with H2O a bad idea?-2008_0330friedrr0031.jpg   possible tank leak...is filling with H2O a bad idea?-2008_0330friedrr0033.jpg
Old May 11, 2008 | 11:36 AM
superbling's Avatar
If it was spray painted, then the source of the leak should be obvious as fuel eats most sprays. Looks like the tank has been at least 3 colors (black, yellow, red) so I'd assume it's been dented before; maybe hard enough to finally leak.
Not sure how water would help.
Old May 11, 2008 | 01:42 PM
SlowHAWK's Avatar
You could try a bit of compressed air... probably wouldn't need more than 10-15 psi to start hearing some air coming through if your able to block off the openings.
J.
Old May 12, 2008 | 05:22 AM
andy9743's Avatar
she's been black, red, yellow then black again... and it has been dented (stripping it for a repaint) i thought i'd use the h2O to attempt to find the leak. i can't seem to find the source. i'll try the air and see where that gets me.
Galaxieman
Jun 15, 2009 10:09 PM
andy9743
Mar 30, 2008 12:33 PM
snowman666
Jun 4, 2007 08:40 AM
Shawn Torpey
May 2, 2007 05:50 AM
demetri
Mar 7, 2005 09:59 AM
