Overheating
Old Sep 9, 2011 | 02:28 PM
05Titan's Avatar
05Titan is on a distinguished road
Overheating
Had a very slow (maybe 25mph) low side slide into some grass and damaged the right fairing. Cracked right below the bottom front corner of the radiator opening, so I'm thinking that's where I might find the cause for overheating. It stayed hot as I drove it home, but only broke 250 degrees when I sat at one traffic light. Got home pretty quick. Most of the ride home the temp was around 220.
Any ideas where else I should look for trouble would be appreciated.
Old Sep 9, 2011 | 02:42 PM
divingindaytona's Avatar
Remember stock is BAD!
First thing to look at is the thermostat.
Old Sep 9, 2011 | 02:45 PM
nekkid's Avatar
You might have damaged or jammed the fan. Check to see if it spins freely.
Old Sep 9, 2011 | 03:04 PM
This where I would start and if it is stuck (or even if it is not ) check the fuse. After that would be (of course after checking to see that the system is full) would be the radiator cap. Even if it isn't bad, if you don't know when you replaced it last, it's a good thing to do and should be done every couple of years just like changing the coolant.
So as it does sound like either the radiator moved a little bit and jammed or something got stuck in there and it then blew the fuse.
Still it would be a good time to flush and fill the cooling system if you haven't done it for a while.....
Old Sep 9, 2011 | 03:05 PM
uebergang's Avatar
uebergang is on a distinguished road
nekkid and daytona, are right with thermo and fan, if its not that then start with checking conections, wires, rad cap, fan temp switch, air in system as per the manual... many more info ?
thatbloke
Sep 19, 2010 12:52 PM
amhsraptor
May 15, 2010 06:56 AM
Storm
Oct 30, 2009 07:23 PM
RPV-Hawk
Oct 9, 2008 03:30 PM
lynchie
Aug 7, 2008 04:17 PM
