Overheating
Overheating
Had a very slow (maybe 25mph) low side slide into some grass and damaged the right fairing. Cracked right below the bottom front corner of the radiator opening, so I'm thinking that's where I might find the cause for overheating. It stayed hot as I drove it home, but only broke 250 degrees when I sat at one traffic light. Got home pretty quick. Most of the ride home the temp was around 220.
Any ideas where else I should look for trouble would be appreciated.
So as it does sound like either the radiator moved a little bit and jammed or something got stuck in there and it then blew the fuse.
Still it would be a good time to flush and fill the cooling system if you haven't done it for a while.....
