oil capacity?
Old Feb 9, 2007 | 06:23 PM
oicdn's Avatar
oicdn
oil capacity?
How many quarts of oil when doing an oil change? I'm about to change oil on one and there's no manual, and I can't remember how many I needed....how many quarts will I need?
Thanks!
Old Feb 9, 2007 | 08:41 PM
Chitownson's Avatar
Chitownson is on a distinguished road
oil capacity
The Honda shop manual says 4.1 US quarts with a filter change. Just FYI, I dropped the oil pan to clean the pan and oil strainer once and it took 5.5 quarts to get the oil in the inspection window to a decent level. (P.S. -if you don't have a shop manual, I got mine off e-bay for $20 - worth every penney!)
Old Feb 9, 2007 | 09:10 PM
There's a shop manual here on the forum free for download.
https://www.superhawkforum.com/forum...ead.php?t=3673
Fifteenth item down from the top in the first post. When you get to the link, the little picture is of an aftermarket manual but the download is the real thing from Honda.
Old Feb 11, 2007 | 04:17 PM
oicdn's Avatar
oicdn
I only managed to squeeze in 3.75 quarts in there, and the oil level was to the top line....wierd...
Old Feb 11, 2007 | 11:30 PM
marmaladedad's Avatar
Hmm?
5.5 is a LOT of oil. If the bike is on its sidestand, then yes, it's possible to put in that much.
Remember, the bike is supposed to be standing straight when you pour the oil in.
I usually get about 3.7 quarts. A little bit more when changing the oil filter.
Old Feb 11, 2007 | 11:56 PM
Hmm?
On a related note, a racer I spoke with said his bikes are run regularly with low amounts of engine oil (about two quarts). Supposedly it helps the bike accelerate...fast...er....???
Old Feb 12, 2007 | 08:40 AM
bkelsey's Avatar
bkelsey
Originally Posted by BIRDOPREY
I just checked and my kickstart on the left, oil sight glass on the right. Did they change it?
You are the man if you can kickstart that thing, on the left even
Kickstand left, sight glass on the right for me too. Hence, when it's on the kickstand and left of straight up and down, you would need to put more oil into it to read on the sight glass.
About 4 qts. without a filter change and a little over 4 qts. with a fiter change for me.
Old Feb 12, 2007 | 03:36 PM
SuperHawkins's Avatar
Originally Posted by Thumper
too funny, i guess mine didn't come with a kick start, i sure would hate to kick this 996 cc best over with my leg.
Ohhh the pain, thank goodness for the button....
Lol I found out the hard way that these bikes are nearly impossible to even push-start....damn thing would just crank over once and then lock up the back tire....had to pull it with another bike and pop the clutch at around 20 mph and it BARELY started
Old Feb 12, 2007 | 06:28 PM
Birdoprey's Avatar
first: DUH!!
second: mine kicked back while starting once and nearly broke my thumb.
third: when bump starting it helps to try it in second or third gear.
Old Feb 12, 2007 | 06:44 PM
Arrrrg! I hate being wrong , but don't mind admitting it. Marm is correct. Sorry about the confusion. I think I will delete some posts to get rid of the evidence.
Old Feb 12, 2007 | 06:46 PM
first: DUH!!
Tried it in 2nd with the same results... The bike was having electrical issues that day so it didn't want to fire, and once it did get started it made it a few miles down the road and completely died (bad connections at the battery)
And yeah with a filter change, mine took one of those 4 quart...or 4 liter...whatever it was...jugs of Spectro and was right at the perfect level....made it much easier to fill up since my sight-glass has a thin layer of spraypaint over it so you can BARELY see through it :-x
Old Feb 12, 2007 | 07:34 PM
Randman's Avatar
Moderate-whore
We all know the truth....it is out there...................
Old Feb 12, 2007 | 11:23 PM
Hmm?
I thought I was trippin' last night!
Old Feb 13, 2007 | 10:54 AM
No, it was me that was trippin. Too little time with the bikes during these loooooong NY winters isn't good on this hobby/passion of motorcycling. Damn, I wonder how rusty I'll be riding in the spring...
Old Feb 13, 2007 | 08:59 PM
Scooberhawk's Avatar
Señor Miembro, Ay Caramba
..and the conversation continues about non-existing posts..
Greg, why don't you also delete the posts that refer to you being wrong, and destroy all the evidence?
Old Feb 13, 2007 | 10:02 PM
It's more fun this way.
Old Feb 14, 2007 | 04:02 AM
Touche!
Old Feb 21, 2007 | 02:34 PM
fundgh's Avatar
Yeah, the 4Q container (1 Gallon) is 3.7... Litres. The Haynes calls for 3.9L IIRC. I am looking for .2L of Max. Oil...anyone, anyone?! Why couldn't they make the capacity 1 Gallon, for US bikes? The world does revolve around North America doesn't it?
Old Feb 27, 2007 | 08:43 PM
roisman's Avatar
roisman is on a distinguished road
when checking the level of the engine oil at the sight glass, should the engine be idling or turned off? because I notice that the level drops once you've started the engine.
Old Feb 27, 2007 | 08:57 PM
Birdoprey's Avatar
with the engine shut off for at least a few minutes to let the oil settle.
Old Feb 28, 2007 | 05:38 AM
Randman's Avatar
Moderate-whore
So if you hold your breath while changing the oil, and if the sun is in the east even thought the day is done, will the front tire feel the pain of not having the right type of oil in the bike? Just wondering...
I drain the oil, change the filter every time (way to cheap not to) add 3.5 quarts, crank her up and run for 3-5 mins, shut off wait 2-3 mins then check level (while balancing her straight up and down with one had, kneeling PITA) usually have to add about .3 to .4 more....for a grand total of 3.8 to3.9 quarts of synthetic Mobil 1 Gold Cap 15w50....(maybe that will kick off another what kind of oil do you guys use thread?) LOL.....
Old Feb 28, 2007 | 05:56 AM
Be forewarned, I will lock this thread like Fort Knox if it turns into one of these!
Old Feb 28, 2007 | 08:17 AM
roisman's Avatar
Thanks!!
Little_Horse
Sep 20, 2013 06:03 AM
Blackbetty
Jun 1, 2013 01:01 AM
j shizzy wizzy
Feb 24, 2011 07:59 PM
Slim
Aug 18, 2008 09:10 PM
CentralCoaster
Jul 21, 2008 10:54 PM
