Honda HP4 Oil change kit.. less than advertised capacity?
Old May 31, 2013 | 06:30 PM
Blackbetty's Avatar
Blackbetty is on a distinguished road
Hey,
Dont know if its the HP4 kit or the bike but just did an oil change and im not seeing the correct level in the viewing glass.
Did the usual thing of running the machine home from work, put up in pit stand, opened the filler, dropped the plug, pulled the filter and bleed the thing for an hr.
Came back and refilled with the full 4lt in the kit plus another 1lt.. so a full 5lt.. still no sight of oil in the glass.
Where did it go?
Hyanes says the following:
Oil change - 3.7lt
Oil and filter - 3.9lt
Full engine overhaul dry engine - 4.1
Apparently mine just has a parallel universe residing in the sump or something?!?!
Old May 31, 2013 | 07:08 PM
Before you refill it you need to reinsert the drain plug.
Mine's never needed more than about 4.5qt w/ filter change.
Old May 31, 2013 | 07:11 PM
Mikael's Avatar
Mikael is on a distinguished road
Should take the stated amount of oil as per the manual you have.
Hate to ask but did you attach the oil filter and replaced the plug?
You have added way to much oil and is not good if you try to run it that way.
NM Wolverine beat me to it took to long to type
Old May 31, 2013 | 07:40 PM
Maybe you went right by the sight-glass and never saw the oil level. You have the bike up straight when viewing the level, right?
Super Hawk Pro's Avatar
Super Hawk Pro is on a distinguished road
Umm is it still on the race stand instead of tires?
Old May 31, 2013 | 08:32 PM
Unless it is some stand I've not seen, not going to make enough difference to cause the oil to NOT SHOW in the window as the Op stated.
Old May 31, 2013 | 08:34 PM
5L is too much .. period.
If you have the bike level or at least straight up (like even on a rear stand) .. at 5 full L... you likely have filed above and past the full height of the site window.
Old May 31, 2013 | 11:06 PM
Agreed
Old May 31, 2013 | 11:23 PM
jerryh's Avatar
Not used to seeing clean oil in sight glass?
Old Jun 1, 2013 | 12:57 AM
Blackbetty's Avatar
Winner! Yep.. totally missed it filling past the window.
Doesn't help the garage is dimly lit which aided in thinking nice clean oil was general glass discolouration. Problem solved.. but cheers for all the suggestions guys..
Old Jun 1, 2013 | 01:01 AM
Blackbetty's Avatar
that would be it..
Let this b a lesson to all.. trust the manual. Lol
Sherm831
May 18, 2010 07:07 PM
Rydebye
Aug 13, 2007 04:28 PM
oicdn
Feb 28, 2007 08:17 AM
Scooberhawk
Aug 1, 2006 02:36 PM
FRANKSVTR
Jun 14, 2006 02:15 PM
