OEM CCT question
Old Jul 9, 2014 | 06:54 PM
jswisc's Avatar
jswisc is on a distinguished road
OEM CCT question
I obtained a new OEM pair of CCT's free. I am going to install on my 05'. There is a metal tab where the bolt head would be normally. I looked in the service manual and they show a cam chain tensioner lifter but that's not it. I attached a pix. I assume this tab is a way to keep the spring fully tensioned. I just don't know how to release it once installed. Anybody done this before?
Old Jul 9, 2014 | 08:04 PM
It's to hold tension on the spring.
After it is mounted pull back slightly on the key and it will pull out of a slot and be able to rotate.
Some just pull it out but then the plunger slams into the chain follower so I pul it back until it wants to turn and then unwind it until it bottoms.
Old Jul 9, 2014 | 08:19 PM
jswisc's Avatar
Ok, I take it that once it pulls out a liitle it is slotted so you can rotate. Does just come out after rotating?
Crashrat
Oct 11, 2012 08:25 PM
Tebs
Sep 4, 2012 03:06 PM
Shortlived99
May 8, 2008 05:36 PM
mikenap
Jun 24, 2006 07:29 AM
EngineNoO9
May 17, 2006 05:02 AM
