No turn signals working
Old May 7, 2014 | 05:24 PM
superman22x's Avatar
superman22x is on a distinguished road
Small issue on my bike. None of the turn signals are working, but the running lights are working. I'm thinking it's the relay, but before I buy parts, I wanted to see what is the common item that fails on the Superhawk in this situation? Do the switches commonly fail as well? I think I will just replace the relay with an aftermarket digital relay, the OEM FR-3303 seems a bit pricey from what I have found.
Old May 7, 2014 | 07:51 PM
rz_racer_69's Avatar
Old and dangerous
It's commonly the switch on the handlebar. Had the same problem. Took the switch apart and cleaned the contacts, problem went away.
Old May 8, 2014 | 05:06 AM
So, I did some multimeter testing, and found that the switch is working. I tested continuity from the gray wire (center wire) in the relay connector to the right and left turn signal. The circuit closes fine when the switch is turned on. So I then decided to plug my relay back in, and it worked... Weird. It's a little slow to start blinking, and the switch feels gummed up. I think I will take it apart for cleaning.
Old May 8, 2014 | 02:26 PM
dmount76's Avatar
dmount76 is on a distinguished road
If a bulb is out it can really screw up the way the lights work.... check the simple things first.
Old May 8, 2014 | 03:43 PM
Yep, one bulb is out, I'll have to replace that and see if it's any different. Although, I bought some LED flush mounts for the front, so once I put those in, I might need a digital relay anyway.
Bloke
Apr 20, 2015 07:56 AM
superman_006
Jun 30, 2009 05:46 AM
johnclopp85
May 13, 2009 07:20 AM
VTR-2-GO
Sep 8, 2008 02:58 PM
