cams
Old May 9, 2014 | 02:13 PM
tylerjensen's Avatar
tylerjensen is on a distinguished road
cams
After checking my valve clearance the cams are sticky... Barely want too move any ideas??
Old May 9, 2014 | 02:22 PM
thetophatflash's Avatar
Hmmmm? anymore info available?
Old May 9, 2014 | 02:31 PM
How long have the heads been sitting?
Old May 9, 2014 | 04:54 PM
Debris under the cam caps / cams.
Mis torqed cam caps
Debris between the bucket and head
shim out of place
Cams mis timed and you have valve/ piston interference
Old May 9, 2014 | 11:58 PM
its been sitting for about a month... the cam chains are not on the sprockets so it cants be valve interference... i am just totally lost i have no idea whats wrong.
Old May 10, 2014 | 03:02 AM
jerryh's Avatar
Spark plugs out?
Old May 10, 2014 | 04:13 AM
hawxter996's Avatar
ole dirty bastard
have you turned the crank while the chains are disconnected?
if so you probably have valve to piston interference.
eta..........open up your manual and follow the steps to the letter.........or throw the manual out the window and seek professional help.
sounds like you have it out of time.
Old May 10, 2014 | 07:16 AM
Did you use some assembly lube when reassembling the cams?
Old May 10, 2014 | 01:33 PM
grnell's Avatar
grnell is on a distinguished road
cams
Inadvertent swap of cams or caps?
Old May 10, 2014 | 03:02 PM
I think we have a winner.
The cams are marked for intake and exhaust.
Edwards07
Aug 23, 2007 02:47 PM
Stumpy
Jun 8, 2007 10:35 PM
mikstr
May 3, 2007 02:24 AM
jamesvtr
Apr 17, 2007 06:11 PM
Mick-e
Feb 27, 2007 05:20 PM
