No power
Old Apr 23, 2007 | 04:14 PM
madmike's Avatar
madmike is on a distinguished road
No power
My bike started just fine yesterday, but 2 mi. from home it died without warning. Checked the 30 amp fuse under the left rear cover and it was blown. Tried the spare and it blew instantly. After I got the bike home I checked the battery out and it is fine. When I turn the key on I have nothing at all. I have checked all the main heavy cables and none of them have bare spots. Anyone have this happen before?
Old Apr 23, 2007 | 05:57 PM
steener's Avatar
steener is on a distinguished road
Exact same thing happened. Regulator/rectifier failure. I think just about everyone on this forum has had one fail.
Old Apr 23, 2007 | 07:59 PM
Not everyone....
Old Apr 24, 2007 | 05:41 AM
RickB's Avatar
Not everyone....
Lets hope you didn't just jinx yourself!
Old Apr 24, 2007 | 09:32 AM
SH1000MA's Avatar
SH1000MA is on a distinguished road
going throught the same thing mike
Old Apr 24, 2007 | 09:45 AM
Blurr's Avatar
Blurr is on a distinguished road
See I had the same problem but my bike was just died and had no power and I mean I had someone test it and I was 12V and then 13+V and still now I am waiting to see what happens
Old Apr 24, 2007 | 09:54 AM
trinc's Avatar
replace the fuse, unplug the R/R and try & start it. the battery won't be charging so don't run it down to far.
if all seems ok measure the stator (~ .5 ohms wire to wire ) and check stator wires to ground. if that is OK, good bet it's your R/R.
if it still blows then you need a good ohm meter & start checking the wiring harness.
tim
Old Apr 24, 2007 | 09:57 AM
Blurr's Avatar
Well what, in my case I have a brand new battery brand new RR yet my battery died
Old Apr 24, 2007 | 10:06 AM
Blurr's Avatar
What wires should I be checking ? I mean when I took off the battery I got 12V with the key off and then over 13V with it running
Old Apr 24, 2007 | 01:44 PM
rossi's Avatar
rossi is on a distinguished road
It will charge at i higher rate when its running ,they should be at about 13/13and a half volts when running to put back the charge that bike uses when it's runing lights ect.
If it's popped the fuse then it's over chargeing,it sounds like the regulator/rectifier has failed.
It does the same job as the regulator pack on the altinator on your car.
Old Apr 24, 2007 | 02:25 PM
Darkone22's Avatar
Darkone22 is on a distinguished road
Not everyone....
Thats not good ........ U know whats going to happend now dont you! a nother one bits the dust
Corona Hawk
Mar 28, 2007 05:15 PM
drkwaterdiver
Nov 8, 2006 07:23 AM
penst8grad
Sep 14, 2006 07:51 AM
itsjason13
Jul 31, 2006 04:04 PM
HAWK24
May 4, 2006 08:45 AM
