New Issue
Old Jun 16, 2010 | 03:29 PM
98ILVTR's Avatar
New Issue
I replaced the R/R a few days ago, and today I got to take the bike out and ran into more issues. It starts, but once I start it, the kickstand light doesn't work. Then when I put the bike into gear, the bike shuts off. Its almost as the clutch isn't being recognized. The R/R is off of a 2006 R6.
I don't know where to start with this one?
Old Jun 16, 2010 | 03:44 PM
bjorn toulouse's Avatar
Destructive Tester
Side stand switch might be the problem. Check your connections.
Rex
Old Jun 16, 2010 | 03:47 PM
mdbuehler's Avatar
mdbuehler
Kick stand switch loose / unplugged? I believe you'll see it down at the base where the stand bolts in, there will be a plunger that gets pushed when the stand is up (not near my bike, so apologies if I'm thinking of something else I rode).
Trace that back and see if its disconnected somewhere, it should have a plug. You can also unplug them and jumper the bike side (not stand side) of the connection with a paperclip to simulate the circuit being closed. See if that makes it behave any different.
Old Jun 16, 2010 | 06:12 PM
996Riders's Avatar
996Riders is on a distinguished road
g0t the same problem but mine acts like that once the bike is warmed up
Old Jun 16, 2010 | 07:27 PM
98ILVTR's Avatar
Its ok down by the kickstand. I am going to pull the seat to check the other plug!
Old Jun 16, 2010 | 07:59 PM
98ILVTR's Avatar
Its fixed. My guess is that the side stand plug wasn't seated all the way (the one under the seat).
Old Jun 17, 2010 | 03:57 AM
Destructive Tester
Good that you solved the problem. While you're under the seat, it would be a good idea to check all of the connectors and add a bit of dielectric grease to each of them.....corrosion never sleeps!
Rex
kenhawk
Oct 23, 2025 06:05 PM
dmount76
Oct 8, 2013 08:47 PM
woodsrider1
Oct 3, 2011 11:23 AM
midijunky
May 12, 2007 11:25 PM
Pookbe
Apr 25, 2007 11:12 PM
