New superhawk owner no start issue
Old Oct 7, 2013 | 07:21 AM
dmount76's Avatar
dmount76 is on a distinguished road
Hello all. I've been enjoying reading the info you've shared here. Pick up a 1998 SH VTR 1000 yesterday for $500. Best I can gather it has sat in the guys garage for the last 1.5 years. The rear bearings went out and he never bothered to fix it. I picked up a rear wheel all set up with bearings on ebay yesterday.
In the mean time I'd like to get the bike running.... Of course the battery was shot, but hooked it up to my charger to turn it over. (after emptying the tank and putting in fresh gas). Turns over nice and acts like it wants to fire but won't catch. If I give it a shot of starting fluid it will run till it burns through the starting fluid so I'm guessing it is a fuel issue.
I removed the tank and verified that fuel comes out of the petcock when I suck on the vaccume hose. I'm thinking the next step is to go through the carbs. What do you all think? Any other simple tests I can do before tearing into it? Thanks in advance.
Old Oct 7, 2013 | 07:43 AM
sailorjerry's Avatar
Yes, the next step would be to remove the carbs and give them a full cleaning and inspection, after installing the carbs make sure you sinc them. This is most likely your issue.
Also with the bike sitting for so long i would recomend any of the following, replace CCT's with new OEM, replace the CCT's with manual CCT's, or make your OEM CCT's into manual CCT's. Your choice, there are great write ups on all of these in the knowledge base section of the forum.
Old Oct 7, 2013 | 07:48 AM
dmount76's Avatar
Thanks Sailorjerry.
cct?? Cam chain tensioner??
Old Oct 7, 2013 | 08:28 AM
Originally Posted by dmount76
Thanks Sailorjerry.
Yes, cam chain tensioner.
If the PO already converted to manual just check its adjustment.
Old Oct 7, 2013 | 08:33 AM
Wicky's Avatar
yup - CCTs esp the front have a nasty habit of failing
Also replace R/R (Regulator/Rectifier)
As mentioned the knowledge base section contains a lot of useful info inc. a downloadable PDF & searchable Honda service manual.
Old Oct 7, 2013 | 09:02 AM
mput's Avatar
Ditch Magnet
mput is on a distinguished road
Drain and flush the cooling system. Replace with oem honda Coolant.
Old Oct 8, 2013 | 08:47 PM
dmount76's Avatar
Went through the carbs tonight and bike fired right up. Man this thing sounds great. Now I just need that rear wheel to arrive and take it for a test drive.
Goku dua
Mar 27, 2014 05:15 AM
rpolliard
Jan 15, 2013 02:05 PM
Montana
Aug 7, 2010 07:12 PM
Herbie
Apr 16, 2010 08:45 AM
uchi
Sep 24, 2009 04:13 AM
