New Battery...
Old Jun 14, 2011 | 06:31 AM
98ILVTR's Avatar
New Battery...
I just replaced the battery on my SH, and now its dead again. I am starting to think its the Stator. What do you guys think?
Old Jun 14, 2011 | 07:05 AM
evines's Avatar
It's more likely the R/R. Superhawk stators don't go bad very often. You'll need to run some tests though, as there is no other way to know for sure what's going on.
Old Jun 14, 2011 | 09:12 AM
98ILVTR's Avatar
R/R was replaced already.
I did have an accident almost two years ago, and it went down on the Stator Cover.
Old Jun 14, 2011 | 09:23 AM
R/R was replaced with what? Unless it is a mosfet type, it could have died again, and if it is a direct plug replacement it probably did die again.
To test the stator, unplug the R/R and check the ohms between each of the yellow wires and to ground. There should be no connection to ground at any of them, and between each should be a small amount of ohms that is similar between all 3 wires. (no exact # here, just a low number) If this passes, your R/R fried again.
Old Jun 14, 2011 | 09:29 AM
Old Yeller's Avatar
best idea is to do some testing with a volt meter.
Old Jun 14, 2011 | 07:33 PM
98ILVTR's Avatar
An R6 R/R.
Ok, here is an update: when the bike gets hot, it has a tough time starting, if it even starts. But when it cools off, it cranks up like no other.
TWal
Apr 29, 2017 09:07 AM
8541Hawk
May 7, 2011 09:41 AM
Blueracer
Apr 21, 2010 05:06 AM
barrysuperhawk
Mar 28, 2010 02:18 PM
doctermac
Sep 25, 2008 10:36 AM
