New Battery...
I just replaced the battery on my SH, and now its dead again. I am starting to think its the Stator. What do you guys think?
It's more likely the R/R. Superhawk stators don't go bad very often. You'll need to run some tests though, as there is no other way to know for sure what's going on.
Originally Posted by evines
(Post 306055)
I did have an accident almost two years ago, and it went down on the Stator Cover. |
R/R was replaced with what? Unless it is a mosfet type, it could have died again, and if it is a direct plug replacement it probably did die again.
To test the stator, unplug the R/R and check the ohms between each of the yellow wires and to ground. There should be no connection to ground at any of them, and between each should be a small amount of ohms that is similar between all 3 wires. (no exact # here, just a low number) If this passes, your R/R fried again. |
best idea is to do some testing with a volt meter.
Originally Posted by lazn
(Post 306075)
To test the stator, unplug the R/R and check the ohms between each of the yellow wires and to ground. There should be no connection to ground at any of them, and between each should be a small amount of ohms that is similar between all 3 wires. (no exact # here, just a low number) If this passes, your R/R fried again. Ok, here is an update: when the bike gets hot, it has a tough time starting, if it even starts. But when it cools off, it cranks up like no other. |
