Needle height.
Old May 12, 2008 | 02:23 PM
TheRezyReb's Avatar
TheRezyReb is on a distinguished road
Needle height.
surging = lean condition right?
Old May 12, 2008 | 04:08 PM
For the most-part, is it surging when the bike is cold or hot? What RPM range?
Old May 16, 2008 | 05:05 AM
BlackHawk04's Avatar
rubber side down
BlackHawk04 is on a distinguished road
Same here, surging in the lower speeds - 10-25 mph. I poked some holes in the stock pipes and I'm getting the poppity pop when its cold at slow speeds too. How to richen??
Old May 16, 2008 | 07:10 AM
TheRezyReb's Avatar
Problem solved, just moved the needles up.
Old May 16, 2008 | 11:52 AM
RickB's Avatar
You can also shim the needles if you still have the stockers in there... #4 brass washers work well for that. the ones I put in (1 per carb, stock exhaust still) were approx .025"
Old May 16, 2008 | 07:58 PM
You're popping on decel is from PAIR if it has not been disabled/removed.
Old May 17, 2008 | 01:38 AM
rubber side down
It's on accel, mainly just when cold. What is pair? Thanks
Old May 17, 2008 | 05:45 AM
PAIR description, etc. is in the Knowledge Base. Is the popping on accel through the pipes or through the carb?
Old May 17, 2008 | 07:00 AM
rubber side down
Carb
Old May 17, 2008 | 07:25 AM
Yup. Running lean. Rejet or shim the needles.
Old May 21, 2008 | 02:04 AM
rubber side down
Thanks for the feedback. Fiddled with the carbs a bit, cleaned them (seemed like some residue in them?) blew out the filter and meanwhile i had drilled out the pipes. For whatever reason the thing is running way better than before. Sounds great too!
Old Jul 21, 2008 | 07:51 PM
BLAKCK HAWK's Avatar
BLAKCK HAWK
2 quetions sir
1]HOW DID U "drilled out the pipes" ,
2] and did u only clean your carbs to get a smooth running bike or did u jet-it ?
Old Jul 21, 2008 | 07:53 PM
BLAKCK HAWK
what's the difference between rejetting and shimming ?
my bike surges on light accel sometimes hard accel.
has k&n, and gutted stock pipes.
tremaineiz
Apr 29, 2007 10:15 AM
DDohio
Apr 24, 2006 09:27 AM
NOrrTH
Mar 23, 2006 11:44 AM
NOrrTH
Nov 11, 2005 01:48 PM
wormeater
Jun 8, 2005 02:11 PM
