Need some help replacing aftermarket headlight
Old Mar 18, 2009 | 12:53 PM
Reason's Avatar
Greenmeansgo!
I currently have an 8" round on my streetfighter. I bought an Acerbis Cyclops cheap off craigslist.
The round has three wires: green, white w/blue stripe, and blue. This is a wrapped set coming from the bike.
The acerbis has a pair of green/white for low, a pair of green/white for high, and a set of orange/brown for Euro 5w parking light.
Not worried about the parking light but how do I combine the two pairs of green/white on the acerbis while retaining high/low capability?
As an aside, will the stock electrical system on the Hawk handle 110w if I decide to mod the acerbis to run both lights on "high?"
PS, green = negative in this case, right?
Old Mar 19, 2009 | 01:36 PM
Reason's Avatar
Greenmeansgo!
Alright, so I was reintroduced to the idea of a common ground. Trial and error showed me the blue wire is for the high beam, white w/blue stripe is low, and green is ground. I touched bare wires on the Acerbis and everything worked the way it should with each light connected individually.
I crimped the wires together with butt-connecters, combining the two grounds from the headlight to the single on the bike. Now it won't light up at all. I had to go to work so I couldn't do anymore on it, but any suggestions in advance would be welcomed.
Also bumping for knowledge on both lights on high/110w feasability.
Old Mar 20, 2009 | 09:28 AM
Reason's Avatar
Greenmeansgo!
And, I've hosed it
Alright, took apart my connections from yesterday to do some bare-wire testing, make sure I didn't do something stupid, and I can't get anything, AND it won't start. Brake/tail, blinkers, horn, all work fine. Killswitch is set to RUN, it's in neutral, sat on it and pulled up the kickstand - nothing. WTF did I do?
this is really frustrating.
Old Mar 20, 2009 | 09:32 AM
Little_Horse's Avatar
2nd mouse gets the cheese
a fuse is blown somewhere so check those. Also instead of connecting two lights to one circuit, or ground it would be better if you created a second circuit to handle the added load of 2 lights. You can do this by adding a relay circuit off of you battery. Then you connect one light to the new circuit and one to the original wiring harness.
Old Mar 20, 2009 | 09:34 AM
yruyur's Avatar
mine did the exact same thing when I was working with my headlight wiring. I found I blew the headlight fuse and the bike was completely dead, would not start until the headlight fuse was replaced.
Old Mar 20, 2009 | 09:35 AM
Ironically the headlight is connected to the same fuse as your starter, I once blew the fuse on a trip, didn't have an extra fuse so I ended up have to bump start the bike in second, what PITA
Old Mar 20, 2009 | 10:06 AM
Reason's Avatar
Greenmeansgo!
That was exactly it, I wouldn't have guessed the two were off the same one so I was freaking out wondering what the hell I did this time. For all the crap Honda engineers get about their CCTs and R/Rs, I sure as hell am glad they put a spot for an extra fuse right in the box, just saved me a 20 minute drive to the hardware store.
Thank you!
Westley Dotson
Jun 26, 2015 08:36 PM
CruxGNZ
Apr 30, 2015 09:11 PM
XKyleX
Jul 20, 2014 06:40 PM
mrmhrm9598
Apr 8, 2011 08:34 AM
Scumbag
Dec 11, 2007 09:08 AM
