Ned Help with Regulator/Rectifier Connector Replacement Pat #
Hiya,
Does someone happen to know which of the part numbers at the link below is the correct connector for the VTR1000F? (In other words, which Honda motorcycles use the same regulator/rectifier as the SuperHawk/Firestorm?)
Ricks Motorcycle Rectifier/regulator wiring harness connector kit - Procycledepot.com
Thanks.
--Professor Chaos
Thanks.
--Professor Chaos
Need Help with Rectifier/Regulator Connector Part#
Hiya,
Does someone happen to know which of the part numbers at the link below is the correct connector for the VTR1000F? (In other words, which Hondas use the same Regulator/Rectifier as the SuperHawk/Firestorm?)
Thanks.
--Professor Chaos
Thanks.
--Professor Chaos
It might be that both part numbers would actually work; I am just trying to eliminate the possibility of having to order the part twice. (I called the phone number on the Web page, and they told me that they do not have any cross-reference information on standard Honda R/R's, and she had no reference index beyond the part numbers and associated models listed on the page at the link.)
Thanks again for the help.
--Professor Chaos
Here's a complete list of every model and year that uses the same stock regulator. Hopefully one of those models is on the drop down menu and you will figure out which clip to use.
http://www.ronayers.com/WhereUsed/N/9935
Part number is 31600-MV4-000
Thank you very much.
The Ron Ayers reverse-lookup search engine for parts does the trick!
(Now that I think of it, I remember someone--a long time ago--telling me that the VTR1000F has the same rectifier/regulator as the CBR900RR and the CBR600-F4. I guess that person was right. lol)
cheers,
--Professor Chaos
cheers,
--Professor Chaos
superbling
Mar 10, 2008 03:02 PM
