Oddball Regulator connector sizes
Old Mar 8, 2011 | 04:53 AM
archaicguy's Avatar
I was just wondering what's up with the larger female plugs needed on the regulators? They are larger than the typical 1/4 and hard to find. I know I can buy the correct connectors from EBeaver but money is tight and I thought I could get my regulator swap done easily. Silly Me.
The stock reg has 3 regular size and 2 large while my zx10 replacement has all 5 large.
Old Mar 8, 2011 | 05:04 AM
Keep in mind that using open connectors usually mean you need to re-do it or atleast clean it pretty soon as it's open to the elements and corrodes... Just saying...
Old Mar 8, 2011 | 05:34 AM
98VTRrider's Avatar
Not sure your situation exactly, but what I did was cut the plug off my superhawk harness, then I soldered on the plug with a few inches of wires from my donor Regulator(I used a TL1000).... Of course if you don't have the plug/wires from the ZX10 you are using that won't help....
Old Mar 8, 2011 | 06:49 AM
JDRiderCoach's Avatar
JDRiderCoach is on a distinguished road
wish I could have done it that way, that sounds better. I did a Gixer R/R, cut the fried Honda connector and crimped 5 individual female spade lugs, plugged one by one into the R/R. Makes me think I need to check it for corrosion now. Good luck and let us know how it turns out.
ProfChaos
Dec 20, 2011 09:58 PM
cperson
May 21, 2009 12:30 AM
trackdayhawk
Aug 8, 2008 08:05 AM
Starbucks Fueled
Jul 29, 2008 03:58 PM
standzchop
Sep 28, 2005 05:51 PM
