motor noise
Old Jan 14, 2009 | 08:06 AM
mcbrien's Avatar
mcbrien is on a distinguished road
motor noise
I have 74000 mi on my super hawk and I thought I would
post up on a oddity this bike does I've never experienced
on any other bike . When chain gets a little loose I get this
knocking under acceleration that sounds like it's comeing
from the motor . First time I thought my cam chain tensioner
was on the way out . I adjusted my drive chain and knocking
went away until chain loosens up again . When chain gets to
the point that adjusting chain at tight spot it still knocks because
of uneven chain wear I replace chain and sprockets and all is fine.
I've been through 4 or 5 chain / sprocket changes and it's always
the same scenario . I'm selling my bike but I have had no problems
and it's never let me down .
Old Jan 14, 2009 | 08:15 AM
What CCT's do you have? APE's or Stock? Mine had a lot of weird noises that went away when I upgraded to APE's at 54000 miles.
Old Jan 14, 2009 | 08:34 AM
Erik S.'s Avatar
No, he's correct. If it's loose, it makes a nice chain slapping sound. Scares ya, ya think it's CCTs, then you adjust the chain to spec, and it get's real quiet by your left foot. Mine did this recently. I had the fear of imminent CCT failur, bought a set. Looked at my chain and felt STUPID! So I'll install the CCTs cause I have them, not cause I need them, YET.
Old Jan 14, 2009 | 09:16 AM
You guys could probably do with a bit more chain lube and cleaning... If it's not taken care of properly it wears and stretches... Well cared for it lasts a lot longer...
Old Jan 14, 2009 | 09:31 AM
Erik S.'s Avatar
This was shortly after purchasing it. PO abused it. Mine is well cared for.
Old Jan 14, 2009 | 10:24 AM
mcbrien's Avatar
I replaced tentioners at 32000 mi when I needed my 1st an only
valve adjustment .
Old Jan 14, 2009 | 02:52 PM
finepooch's Avatar
clean with kerosene and toothbrush. then lube with liquid performance chain lube. my chains last forever.
Old Jan 14, 2009 | 05:10 PM
ScottOiler. Nuff said!
01-hawkster
Jun 20, 2008 06:41 PM
Ausie996
Apr 21, 2007 04:13 AM
mikstr
Apr 14, 2007 05:15 PM
GautamCity
Nov 9, 2006 08:15 PM
gssbmm
Sep 7, 2006 09:43 AM
