missing on a cylinder
Old Dec 24, 2009 | 06:26 PM
4bangeranger's Avatar
4bangeranger is on a distinguished road
hey guys i m new to this site.. i just got a superhawk last errk and i love it.. how ever i am having a problem with it. at idle it missis up too 4 grand then it runs good to 7 where it will miss again. i have a k&n air filter and kurker ext. i cleaned the carbs with no improvement. i also checked my valves and it was all in spec. im thinking it may not be jetted right or carbs may need to be syncronised. it would help alot if i could get some tips
thanks guys
Old Dec 24, 2009 | 07:17 PM
Welcome.
There have been a few people with this problem, and there are several possibilities:
The easiest one to check for is what we call PVLIR, that is petcock vacuum line inadvertent relocation. The small hose to the petcock goes on the rear of the petcock that points to the right, and not on the one on the bottom that looks like where it goes.
The next possibility is if this only happens in the rain, it is likely to be the tank vent hose because that needs to be rerouted from the stock location otherwise it gets plugged with water.
Also often when you get this symptom it is a bad coil.. They may even test fine and still act up this way, the only real way to tell is to swap them out and ride it.
If I have forgotten any (and I am sure I have) someone will chime in. This is not a common problem, but it has happened enough that these are the fixes I recall.
Old Dec 24, 2009 | 08:08 PM
Just_Nick's Avatar
Who are you?
The petcock itself ma also be damaged.
Old Dec 25, 2009 | 10:15 AM
Also did you have the bike jetted for the K&N? If not, go back to a stock filter to see if that helps. Our bikes are picky about filter changes, not so much about exhaust.
Old Dec 25, 2009 | 10:57 AM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
As Lazn suggested, This is a rather common occurance on this bike, I have read of several instances as well as my own experience.
Additionally to this, you should disconnect the PVLIR line from the intake port fitting and apply vacuum(or suck on it using a CLEAR hose and see if fuel is leaking past the diaphram directly into your intake port. Which will foul your plug in a major way.
The sure fire way to check this, since it will ride virtually the same whether the front or rear cyl is not firing, (without buying an extra coil) swap coils from front to rear, rear to front... Having checked which cyl was cold prior to the swap, you can now determine if the "cold" cyl has swapped positions, following the bad coil.
I do this using a cheap screwdriver handle and touching the exhaust header about an inch from the port, you will notice a significant difference in which the handle will melt between the hot and "cold" not firing cyl, checking at diff RPMs will be necesary, depending on when your "missing"
Visually checking for a blue spark is no good! I had a consistant blue spark on the cold cyl, yet it failed to spark when under the cylinder pressure it experiences when installed in the eng.
These are the first, most important, and only steps you should address, until you are 100% satisfied they are ok.
Old Dec 31, 2009 | 01:58 PM
thanks guys
im at my buddys shop now i tested the petcok it tested good and i had the vacume line in the correct place im now going to check the coils. however the air filter it came with a k&n and i have no idea whats up with the jets if they were changed or not. nor do i have the stock filter. should i get a regular filter. and check the jet size. also im still waiting for the choke cable it broke off in the carb so i really need that untill i can really sync or anything like that.. i also saw that the airfilter has a gap im going to silicone after i change the choke cable.. one more question whats the stock jet size.. and what size should i use for the k&n and ext...
thanks guys helped out alot
Old Dec 31, 2009 | 08:02 PM
shayne's Avatar
I would fix your air leaks before you go any further, as these could be the problem.
Old Jan 22, 2010 | 05:02 AM
well the shop said they would take it back and fix it for me so i took it there and it was 3 weeks till i just worked on it my self. had it running so good in 9 hours fixed my coolent leak, my fan not coming on, oil leak, choke cable, swaped my coil. synked carbs.. and fixed air gaps.. now this is the bike i thought i bought.. the ony thing now is when its cold the carbs will sneeze on me.. any idea...
and thanks so much guys helped alot
Old Jan 22, 2010 | 05:42 AM
nath981's Avatar
welcome aboard. ask the shop if they adjusted the TPS. It made a significant diff on mine in terms of smoothness. if not search this forum for the "how to".
Old Jan 22, 2010 | 10:04 AM
gboezio's Avatar
If it sneeze pull the needles up, is there a jet kit on this bike now ??
It will need a bit more fuel, check the plugs, may be white from lean mix.
Old Jan 22, 2010 | 10:14 AM
Little_Horse's Avatar
2nd mouse gets the cheese
"sneezing," I think this term describes it better than a "lean backfire" or a "carb fart"... I motion to replace said terminology from here on out.
Old Jan 22, 2010 | 10:25 AM
ttocsmai's Avatar
Doesn't "carb fart" sound more technical?
Old Jan 22, 2010 | 11:26 AM
well considering a sneeze comes out the intake end and farts come out the exit end I would say no, but we digress.
Old Feb 3, 2010 | 06:52 AM
lol well my tps wires do have tape on them.. they were butt connected to a wire just chilling.. however some old *** lady opened her door on me in a gas station. broke my arm and all my fairings.. dumb bitch lol.. now i have a 20000 hospital bill. now i have to sue her..
Old Feb 3, 2010 | 07:58 AM
Ouch, I went through something very similar last year. A good lawyer is key.
Old Feb 3, 2010 | 02:15 PM
nath981's Avatar
Did you learn anything about cars with people sitting in them?
Seriously sucks, but at least you're alive, huh.
I thought I was doing the prudent thing by positioing myself in the passenger mirror of a pick-up (just off to the side a hair)at a stop light instead of directly behind. Well, this guy decides to back up and let a car out from the gas station on his right. So he starts to back up slowly until I'm sitting tightly against his passenger's door trying to keep my SH from being forced to the ground. Honking my horn, shouting to no avail as his elderly wife evidently couldn't hear and had no peripheral vision because she sat there with her head straight ahead. I don't how i kept my foot from under his rear wheel as he backed up, but I know his truck was pushing me down. Anyway, after what seemed an eternity, I held the bike up with the right hand and smacked their door with the left. Finally, she looked over and jerked with fright and then slowly looked over toward her husband and got his attention. I was able to wiggle away forward but it must have been a funny sight to those watching. Anyway, I did learn something about positioning that day.
Old Feb 3, 2010 | 02:47 PM
nath981's Avatar
It may be little difficult working on you tps, etc. with a cast on, huh/ You can always do what I did after a couple weeks. After sticking pencils and dial rods down to scratch the itch. I finally got the dremel out and cut that sum bitch in half longways. Worked great. took it apart for cleaning, dried my arm well and put it back on with plastic ties. Oh what a feeling., But now my one arm is kinda shaped like and "s", hahaha..........Just kiddin! Cutting it was a great solution for me though.
Old Feb 9, 2010 | 01:24 PM
lol thanks guys.. i hope i dont have to pay for all this ****.. it all add up. and nath your lucky. lol i just got all the parts to fix it just need to be able to move my fingers. there still swolen. any ways i got my broken parts fixed well in at least. also some new bt003 stoked to try those out on a track day. all i have to do now is fix my farings.. but i got my eye on the 11.5 pistons now.... lol
Old Feb 10, 2010 | 07:06 AM
compmoto's Avatar
compmoto is on a distinguished road
coil replacement
I'm willing to bet some chicken that my issue is the petcock vent line misplacement, but what replacement coils are you folks using if that is the issue? I'm a lil "stir crazy" in here with all this damn snow! Any sec now, the power is gonna be out, cuz it's blowing sumthin fierce outside ! If I wanted this , I'd move to Canadia ! Thanx for the info,this site is a great resource ! Happy Shoveling !
speedhawk
Jul 22, 2008 11:12 AM
hermes
Feb 11, 2008 08:44 PM
saxman
Jul 7, 2007 10:21 PM
mdbuehler
Feb 5, 2006 07:51 PM
inderocker
Forum Feedback
Jun 18, 2005 03:51 PM
