Messed this one up.
Messed this one up.
So I dropped by bike for the first time today. There was a car parked next to where I usually do so I had to park at a 90 degree angle to how I usually do. Well when I got off my bike I dropped my keys and when I bent over to get them my bike tipped.
I got it up pretty quickly, but not before the damage was done. There was a huge oil slick from where it was downed and oil coming out of the crankcase.
I cleaned the slick and examined the crankcase and here's what I found:
Pretty nasty huh?
Needless to say I'm in the market for a new crankcase cover.
Oh, and an oil change.
If any of y'all have an extra cover sitting around that's in good shape, I'll be happy to buy it off your hands.
Pretty nasty huh?
Add a coolant change and new gasket to your shopping list
You might want to add a carbon cover and some hi-temp silicone adhesive just in case...
iQc6BM)+QY145g~~_12.JPG)
eBay - The UK's Online Marketplace
Wow that's some darn luck there, you must've hit it on just the right,(or should I say wrong), place. I've tipped mine over in the garage, fell over hitting sand at 15mph' crashed on the track at about 50-60 bike flipping and all I have are scratches! Sorry about your luck but thanks for the post other wise I wouldn't have seen the CF cover.
You will also need a new mechanical seal with the right cover as they usually do not come with one. If you need your bike, I used high temp jb-weld or something similar on mine before I replaced it (after laying it down again from a 5 foot long 5 inch deep pot hole) just to get it running again. For that, you will need to take it off, sand down the outside and the inside after removing ALL OIL. Obviously this fix doesnt need to look perfect, but its good to get a seal from both sides. The cover mainly protects the internals, and there is a minor amount of pressure that goes through there (Ran mine for 4 miles with a hole to get it home).
Have a lower sharkskin and covers on both sides ,fits good
And you get the covers from this guy in Germany
http://myworld.ebay.com.au/carbonadi...84.m1543.l2533
Erno from down under beat me to it
Also last time I had my cover of A can of gasket remover and a scraper helped get the old one off, then using some Liquid Gasket latest type Yamabond Hugh bottle to secure one side (be very careful around the coolant drain hole), while a litttle grease on the other - to help split the cover from the case if I have to take it off in the future,
Firedog - the cover comes from Germany - click the ebay link below the picture in my first post. He also apparently does a kevlar version.
If a lower is that snug onto the engine covers, it would likely make all kinds of rattly noise as it makes contact, and also create some nice rub marks...
It's adding a couple of mm of thickness over the covers... Why on earth would it affect fitment of a lower in any way?
Wicky I'm looking pretty seriously at getting those covers, one for my crankcase and one for my alternator, but I have a question. I'm in the US and the ebay auction is listed in euros. How does that work out?
Cheesedrug
Jun 8, 2006 02:51 PM
